Dell desktop 3472 bios request
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    ModelEll Desktop 3472
    MB Code: 17501-1
    Need bios with txe clean. Old bios dump attached.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell desktop 3472 bios request
    Here it is. Extracted from dell update.
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
    • DavidChunco
      Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
      by DavidChunco
      Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
      - Receive help from Dell Support (it is out of warranty).
      - Disconnect machine from AC power and battery overnight.
      - BIOS recovery process
      - Connected external display via HDMI
      - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
      03-15-2025, 11:00 AM
    • capoplays
      Help with BIOS update on Dell G15 5515 after chip replacement
      by capoplays
      Hey everyone,
      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
      When I check the BIOS using the F12 menu Flash...
      Yesterday, 06:53 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
