Diagnosing a no power/post issue, any help would be great! Thanks!
ASRock H81 BTC Pro R2
by MakNCheeseHi everyone,
I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
Symptoms:- Severe lag across the system, including BIOS navigation.
- Slow boot times and unresponsive performance in Windows.
- Battery charges very slowly (e.g., ~5% in 2–3 hours).
- No error messages or BSODs, just extreme sluggishness.
What I've Tried:- Replaced
by code shareHi everyone,
I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
Here's what I've tried so far:- Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
- Booted successfully on AC power only with the battery disconnected
- Visual inspection of the battery — no swelling, burn marks, or connector damage
- Battery
by Leefreeman97Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?4 Photos
I have an ASRock motherboard (IMB-150) with Mini-Sata Solid State Drive. I have removed the SSD card and re-inserted. After re-inserting the device will not boot up. During boot up error displayed "Reboot and select proper boot device or insert boot media in selected boot device and press any key".
Connections on motherboard and ssd card look in good condition, no signs of wear or damaged connections.
During boot up I pressed F2 to select UEFI setup menu and mSATA 3IE is listed as boot device with no other option available.
Anyone have some advice... -
by rouninHi everyone,
I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
🛠 Original Issue
The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
⚠️ New Problem: One USB-C Port Only Works in One Orientation... - Loading...
