Need Asus B450m-a prime bios .bin dump
  • CapLeaker
    Leaking Member
    • 7975
    I need a more recent Asus B450m-a Prime bios dump in .bin format, so I can flash the SPI directly with my programmer. The main board won't POST anymore. I did find a couple of old dump files, but nothing recent.
    Thanks in advance!
  • peste
    • Dec 2016
    • 12246
    • ROMANIA
    Re: Need Asus B450m-a prime bios .bin dump
    Thanks in advance!
    before writing, make a backup copy of the original bios.
    • CapLeaker
      Leaking Member
      • 7975
      I wish I could. Took the Winbond off the board, put it into my 8 pin SOIC adapter, pin broke off. Argh!!
      Thanks for the file. Have to get a new IC and try it.
      Edit: In linux I can't decompress it properly (has errors) and leaves a 0 byte decompressed file?
      • CapLeaker
        Leaking Member
        • 7975
        Been otherwise occupied lately and I just got around to program and swap the
        Winbond IC out.
        Here is a dump of a working B450M-A bios. Mine is working once more!
        • lazaro84
          • Oct 2021
          • mexico
          tanks for info. https://www.badcaps.net/forum/images/smilies/boink.gif
          • techcare
            • Nov 2017
            • 18
            • KOREA
            Hello this files is damaged coz can't be extracted.Can you please give the good one.Thanks in Advance.
              • 20304
              Update winrar or use 7-zip .
              • badisrep
                • Apr 2021
                • 17
                • algeria
                thank you so much
                • dimarik91
                  • Jul 2022
                  • Russia
                  Winbond IC out.
                  which bios version is this?
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • kcp0085
                    Request BIOS dump for ASUS FA617NS-A16.R77600
                    by kcp0085
                    Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                    I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                    Specs:
                    - ASUS TUF FA617NS-A16
                    - CPU: AMD Ryzen 7
                    - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                    If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                    Thanks in advance!​
                    05-02-2025, 12:52 AM
