Need Asus B450m-a prime bios .bin dump
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    I need a more recent Asus B450m-a Prime bios dump in .bin format, so I can flash the SPI directly with my programmer. The main board won't POST anymore. I did find a couple of old dump files, but nothing recent.
    Thanks in advance!
  • peste
    • 13573
    • ROMANIA
    Re: Need Asus B450m-a prime bios .bin dump
    Thanks in advance!
    before writing, make a backup copy of the original bios.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8340
      I wish I could. Took the Winbond off the board, put it into my 8 pin SOIC adapter, pin broke off. Argh!!
      Thanks for the file. Have to get a new IC and try it.
      Edit: In linux I can't decompress it properly (has errors) and leaves a 0 byte decompressed file?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        Been otherwise occupied lately and I just got around to program and swap the
        Winbond IC out.
        Here is a dump of a working B450M-A bios. Mine is working once more!
        • lazaro84
          • Oct 2021
          • mexico
          tanks for info. https://www.badcaps.net/forum/images/smilies/boink.gif
          • techcare
            • Nov 2017
            • 18
            • KOREA
            Hello this files is damaged coz can't be extracted.Can you please give the good one.Thanks in Advance.
              • 21853
              Update winrar or use 7-zip .
              • badisrep
                • Apr 2021
                • 17
                • algeria
                thank you so much
                • dimarik91
                  • Jul 2022
                  • Russia
                  Winbond IC out.
                  which bios version is this?
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • pirati
                    by pirati
                    Yesterday, 04:20 PM
                  • reset1986
                    Asus prime b550m-a bios dump
                    by reset1986
                    Hi guys, I have this PC that does not display an image, video card and GPU and RAM are working, tested on another PC, I suspect the BIOS is damaged, I attach the original dump, I need a working BIOS, thanks...
                    06-22-2025, 04:17 AM
