[desktop] asrock H81M-DGS R2.0 bios
  • litec systems
    Electronics is
    • Feb 2018
    • 97
    hi
    looking for bin file for H81M-DGS R2.0 ROM
    to be flashed w\ rt809f
    ive tried the instant flash v1.50 from asrock and its says the size of the open file doesnt match the chip capacity
    in additional- thay arent bin files
    hope u can help
    and thanks in advanced
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    Re: [desktop] asrock H81M-DGS R2.0
    here you go
    you need to remove access bite from there
    try now
    • litec systems
      Electronics is
      • Feb 2018
      • 97
      Originally posted by qayyum786
      here you go
      try now
      THANKS BRO !
      could you please tell me where and how to find these bin files myself?
      and or whats that remove access bite? ive googled it quickly but havent found any info about it is it kind of protection? how to bypass that?
      ill flash it and see f itll restore my MB ..[ not sure if its electrical problem(ps + power btn are ok- but it refuses to turn on or bios but i havent much to loosr as i have the programmer as a tv repair hobbyst
      thanks!
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • grimacelord
        by grimacelord
        Hello there.
        History:
        03-15-2023, 03:29 PM
      • AustinCER
        HP ENVY Desktop TE01-1214 - No Display, Powers On, Corrupt BIOS
        by AustinCER
        I currently have an HP ENVY Desktop TE01-1214
        S/N -
        2MO22342GX
        Motherboard - L75365-001
        BIOS Chip - W25Q128JVSQ
        Suspected Windows updates contained BIOS update in which, during update the Desktop PC displayed a black screen to the monitor while still powered on. Display image never restored.
        Tested RAM in both slots, as well as new RAM. Tested a brand new known working i5-10th Gen GPU (Same CPU as original installed). Cleared CMOS. Tested the Desktop PC with a dedicated GPU connected, but still no display. Device will not POST when powered...
        04-25-2025, 05:56 PM
      • gabrieljma1
        Request: Full BIOS dump for ASRock Z790-CX (DDR5)
        by gabrieljma1
        I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
        The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
        I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
        10-08-2025, 03:32 PM
