A68-A-K20BFDP_MB bios bin file
Tags: None
Re: A68-A-K20BFDP_MB bios bin file
try and reportAttached Files -
Is this the A68 chipset, which is of the socket FM2/FM2+ platform?ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
by mitchwJust had a customer bring in a HP 14s-fq1010nm to do some maintenance.
After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...-
Channel: BIOS Requests ONLY!
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... -
by wizard13Hello everyone,
I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
I have checked the forum and the available documentation but could not find a solution specific to my issue.- Brand & Model: Dynabook Satellite Pro C50D-B-100
- Part Number (P/N): PYU13E-00C00PFR
- Serial Number (S/N): 22028896H
- System Configuration (SC): A1PYU13E1127
- Motherboard Model: IP3_ACN16_MB_V21_20211222A
- Power Input: DC 19V –
Hi boys,
This is my first post in BADCAPS and I hope I don't make any mistakes and give the correct explanations.
Yesterday a friend brought me this laptop home to expand the RAM to 16GB of RAM and update it since it had been abandoned recently.
Everything was fine, until I made the mistake of updating the BIOS to version F.73 from version F.24, since after according to HP "updating correctly" the laptop never worked again, leaving the screen black but the fan is working and the light of M.2 is on.
After having carried out all the frequent...-
by EbrahimSiamiHello everyone,
I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
**Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
**What I have tried so far:**
1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...-
07-02-2025, 02:31 PM -
- Loading...
