HP 800 G1 TWR missing mac address
  • zenek_19
    • Mar 2017
    • 73
    • poland
    Could someone add mac address becouse there are only FFFFFFFFFFFFF
    it can be 8CDCD43377E8
    • 21662
    Re: HP 800 G1 TWR missing mac address
    Try these intel MAC address tools.If it doesn`t work try the intel mac address tools from ASRock - https://www.asrock.com/support/download/mactool.asp
    • zenek_19
      • Mar 2017
      • 73
      • poland
      OK thanks MAC changer from ASROCK working.
      • odif
        • Aug 2021
        • morocco
        hi zenek
        hw you did it please ??
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          hi to all, i would also need a little help in changing MAC, can you please give me a little walk ?
          ...the quieter you become the more you are able to hear...
          • jef1995
            • May 2025
            • 4
            • usa
            The files that are programmed have a MAC address but the network still doesn't work.
            • peste
              • Dec 2016
              • 13422
              • ROMANIA
              update the drivers..
              • kotel studios
                Asrock 970 PRO3 - missing 1.1V on NorthBridge
                by kotel studios
                Recently I got this Asrock 970 PRO3 board from scrap. It had a few missing caps under the NB which I've replaced. Sadly, one of them went short (NC597 from boardview file). I did replace it and there doesn't seem to be any shorts left, but the board is not executing POST nor beep codes. I once got it to POST after I was slightly bending it, but that was only once. I tried to redo the same steps but to no avail. All caps on the backside of NB have 22-ish ohms.
                I have traced the problem to an dead Northbridge VRM. There's no voltage on Phase (pin 8), FB (pin 6), UGATE...
                08-02-2025, 02:34 AM
              • ahmedtou
                HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                by ahmedtou
                help me please
                I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                I will share all the details with you, including the disc information.
                Code:
                HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                Current Profile: BD-R
                Disc Information:
                Status: Empty
                State of Last Session: Empty
                Erasable: No
                Free Sectors: 12,219,392
                Free Space: 25,025,314,816 bytes
                Free Time: 2715:27:17 (MM:SS:FF)
                Next
                08-27-2025, 08:49 AM
              • gabrieljma1
                Request: Full BIOS dump for ASRock Z790-CX (DDR5)
                by gabrieljma1
                I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
                The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
                I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
                10-08-2025, 03:32 PM
              • ugamazing
                820-02020 PPBUS_AON missing
                by ugamazing
                Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                02-05-2025, 04:21 PM
              • jpreza
                Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                by jpreza
                I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                Looking at the card, it appears to be missing the following:
                1x 1.0uH inductor - orange square
                2x...
                11-01-2024, 10:54 PM
