Need Bios for 820-3481-A
  • wasaab
    • Mar 2020
    • 16
    Hi all, would anyone happen to have a clean bios dump from an 820-3481 a1419 emc 2639 they would be able to share with me? I would greatly appreciate it.
  • peste
    • Dec 2016
    • 12734
    • ROMANIA
    Re: Need Bios for 820-3481-A
    post the original bios
    • wasaab
      • Mar 2020
      • 16
      Sure, here is the original bios dump and then one that I cleaned the ME region on. I am not having success with it however, and am wondering if another area of the bios got corrupted beside the ME region. The symptom of the iMac is it boots about half way and hangs, I have checked ram on another machine, CPU and SSD drive and all check out so far. Machine comes on and everything seems to be working except for full boot, both from recovery, usb disk and even imaging internal SSD. Thanks for any assistance with this.
      • peste
        • Dec 2016
        • 12734
        • ROMANIA
        try..
        • wasaab
          • Mar 2020
          • 16
          Originally posted by peste
          try..
          Thank you! I will try it today.
          • wasaab
            • Mar 2020
            • 16
            So flashed your version and still same issue, hangs on boot about halfway. Bummer! Thanks for the effort, I really think I need a dump from a donor though. I have a feeling another area might be corrupt outside of the ME region.
            • piernov
              • Jan 2016
              • 4435
              • France
              Try booting a Linux LiveUSB.
              • wasaab
                • Mar 2020
                • 16
                Ok so that is strange, made a bootable Ubuntu USB key and hangs on boot there also. I made a Windows 10 PE bootable USB key and that indeed does boot. This is certainly a head scratcher. Thanks again for your assistance with this. I am at a loss.
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  Boot in Ubuntu in verbose mode and check where it hangs. And boot macOS in verbose mode too and check where it hangs as well.
                  • iv4nosky
                    • Jun 2013
                    • 13
                    • Spain
                    I have same issue.
                    Tried several bios dumps , cleaned its original dump . Checked Me strap at motherboard .
                    Finally no video and only 2 leds. Reballed gpu and video came back.
                    Booted in verbose mode . It says unsuported cpu unsuported PCH .
                    did boot once but got freeze at login . I guess with a no recognize pch , sata controller will be extremely low.
                    If someone have any clue about whats going on with these motherboards will be great.
                    • lordmuken
                      • May 2018
                      • 52
                      • Philippines
                      hello! anyone got a good working bios for 820-3481? my unit only work when i remove cmos battery.
                    • lordmuken
                      • May 2018
                      • 52
                      • Philippines
                      This is the details of my unit, attached with orig bios file
                      S/N: C02ND5F8F8J5
                      EMC: 2689
                      Board Code: 820-3481-A
                      can anyone fix it? or got a known good bios with clean me? thank you
                      • peste
                        • Dec 2016
                        • 12734
                        • ROMANIA
                        S/N: C02ND5F8F8J5
                        EMC: 2689
                        try..
                        • easyfixhk
                          • Sep 2024
                          • HK
                          I had same issue and it was nothing to do with the bios. Got it fixed by re-soldering the GPU RAM. Hope this will help.
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
