Hi all, would anyone happen to have a clean bios dump from an 820-3481 a1419 emc 2639 they would be able to share with me? I would greatly appreciate it.
Need Bios for 820-3481-A
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptions -
Re: Need Bios for 820-3481-A
Sure, here is the original bios dump and then one that I cleaned the ME region on. I am not having success with it however, and am wondering if another area of the bios got corrupted beside the ME region. The symptom of the iMac is it boots about half way and hangs, I have checked ram on another machine, CPU and SSD drive and all check out so far. Machine comes on and everything seems to be working except for full boot, both from recovery, usb disk and even imaging internal SSD. Thanks for any assistance with this.Attached FilesPremium supporters get full download access and other benefits.
try..Sure, here is the original bios dump and then one that I cleaned the ME region on. I am not having success with it however, and am wondering if another area of the bios got corrupted beside the ME region. The symptom of the iMac is it boots about half way and hangs, I have checked ram on another machine, CPU and SSD drive and all check out so far. Machine comes on and everything seems to be working except for full boot, both from recovery, usb disk and even imaging internal SSD. Thanks for any assistance with this.Attached FilesPremium supporters get full download access and other benefits.
https://www.badcaps.net/settings/subscriptionsComment
So flashed your version and still same issue, hangs on boot about halfway. Bummer! Thanks for the effort, I really think I need a dump from a donor though. I have a feeling another area might be corrupt outside of the ME region.Comment
Try booting a Linux LiveUSB.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Ok so that is strange, made a bootable Ubuntu USB key and hangs on boot there also. I made a Windows 10 PE bootable USB key and that indeed does boot. This is certainly a head scratcher. Thanks again for your assistance with this. I am at a loss.Comment
Boot in Ubuntu in verbose mode and check where it hangs. And boot macOS in verbose mode too and check where it hangs as well.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
I have same issue.
Tried several bios dumps , cleaned its original dump . Checked Me strap at motherboard .
Finally no video and only 2 leds. Reballed gpu and video came back.
Booted in verbose mode . It says unsuported cpu unsuported PCH .
did boot once but got freeze at login . I guess with a no recognize pch , sata controller will be extremely low.
If someone have any clue about whats going on with these motherboards will be great.Comment
hello! anyone got a good working bios for 820-3481? my unit only work when i remove cmos battery.Comment
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
This is the details of my unit, attached with orig bios file
S/N: C02ND5F8F8J5
EMC: 2689
Board Code: 820-3481-A
can anyone fix it? or got a known good bios with clean me? thank youAttached FilesPremium supporters get full download access and other benefits.
try..Attached FilesPremium supporters get full download access and other benefits.
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by piratiHello everyone,
by DenizBu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
I had the BIOS cleaned, but the issue was not resolved and there was still no image.
Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
After that, I tried to update the...-
- Loading...
