Lenovo ThinkCentre M73 Tiny Desktop Bios Dump
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    Hi guys really hoping you all can help me out with a working dump for my Lenovo ThinkCentre M73 Tiny ...The previous owner attempted a bios removal and destroyed the bios chip itself.And i was not able to get a backup from it.So i got an identical chip and flashed a downloaded bios dump.But seems like it's not working for me.Just no video..Hoping you guys here can help me since you all have came tru for me many times in the past..thanks.
  • peste
    • 13573
    • ROMANIA
    Re: Lenovo ThinkCentre M73 Tiny Desktop Bios Dump
    try..
    • platinumsteel
      • May 2019
      • 234
      • Trinidad&Tobago
      Sorry for the delay..I was waiting for my Heat Station to arrive...I flashed your bios and it is working ...But am only able to reach post and not able to go into the bios or press f2 to resume..Keep getting an error '' Setup Data integrity check failure '' When i press F1 or F2 to get into the system it just reboots and back at post.Can't boot from USB nothing ..Guess it has another problem or fault with the board..Anyway thanks a lot for this bios to at least get me to Post.
      • peste
        • 13573
        • ROMANIA
        try..
        • platinumsteel
          • May 2019
          • 234
          • Trinidad&Tobago
          Hi peste what happen is those 2 bios that you posted were fine all along..The issue was kind of on my end..I should of let it power cycle 5 times.I used to shut it off on the second cycle..What happen is after I flashed the bios i ended up doing a cmos clear and a 30 second hold down of the power switch..And when it boot up i ended up leaving it to reboot 5 times then it started to operate normally..Sounds weird but yeah..After letting it do those 5 reboot cycles i was able to enter the Bios and everything as normally would..Ended up finishing updating the bios in windows and manually entered the serial and model number and stuff and no more errors it's working fine now..Thanks a lot for your bios dump as always.Been very helpful.
          • zenek_19
            • Mar 2017
            • 73
            • poland
            I need ME regio clean, any help?
            • hasanaga_84
              • Jan 2020
              • 36
              • Türkiye
              thank you it"s works
              • thinkcentrem73
                • Jul 2023
                Originally posted by peste
                try..
                This worked, thank you!!
                • FeerBaron
                  • Sep 2018
                  • 39
                  I have 2 of these puppies and got myself into trouble doing updates. For some reason the efi never runs the capsule so cannot update to imageFH. EC can update and then make for an incompatible bios. Can also end up in manufacturing mode with the beeper if the nvram is erased. The dumps in here for FH all have serials/machinetype missing. Yea you can write them but its a pain. The "dobry" is indeed dobry, but it is an old version 1.5x iirc. So here I post my final dump based on 1.79 with whitelist for wlan, me disabled and descriptor unlocked. Its updated enough for me. May whoever stumbles on this thread next have fun.
                  • tapialeorock
                    Thinkcentre M83 Tiny 10E9 BIOS Dump
                    by tapialeorock
                    Hi, i'm looking for a TC m83 tiny type 10E9 with IS8XT v1.1 board bios dump.
                    I somehow messed up with my bios image and the lenovo boot logo was replaced with nec logo.
                    Lenovo's driver lookup tool is unable to recognize my computer in windows also.
                    Changing the serial number manually with amidedos tool hasn't fixed the driver lookup issue.
                    I have tried with thinkcentre m93p and m73 bios dumps, but none of them restored the lenovo boot logo nor the driver lookup issue.
                    I'll leave my current bios dump.
                    Thanks....
                    09-28-2025, 01:32 PM
                  • hotcrossedbuns999
                    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                    by hotcrossedbuns999
                    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                    3. I could only locate two chips that look like bios chips. Could someone verify this
                    01-03-2025, 12:32 PM
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
