asus P5B-E Plus i need dump bios
  • inspirim
    • May 2013
    • 282
    • Italy
    i need dump bios asus p5b-e plus
    thanks to all
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: asus P5B-E Plus i need dump bios
    Download from Asus support website.
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • Anchar777
      ASUS P1412CE need BIOS DUMP
      by Anchar777
      Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
      06-26-2025, 03:39 AM
