bios dump asus et1612i
  • niku1982
    • Jan 2016
    • albania
    hi all! bios dump for asus et1612i needed, thnx in advance.
  • peste
    • 13562
    • ROMANIA
    Re: bios dump asus et1612i
    Try this...bios extract update site Asus...
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
