BIOS dumped Request for ASUS P5G41C-M LX
  • kimmy0312
    • Sep 2016
    • 12
    • Philippines
    hello guys, does any body has a full dumped copy of BIOS for ASUS P5G41C-M LX. mine was corrupted and doesnt work on any bios from asus site, when I try to used a bios flash reprogrammer tool
  • peste
    • 13550
    • ROMANIA
    Re: BIOS dumped Request for ASUS P5G41C-M LX
    put the bios backup here
    • Claudiomfa
      • Nov 2015
      • 455
      • Portugal
      try and report
      • kimmy0312
        • Sep 2016
        • 12
        • Philippines
        thank you sir, by the is this bios dumped from another image of working board? or a bios file from the website??
        • Claudiomfa
          • Nov 2015
          • 455
          • Portugal
          This is extracted original bios from asus support. this solve your problem?
          • kimmy0312
            • Sep 2016
            • 12
            • Philippines
            i doesnt solve the problem
            • kimmy0312
              • Sep 2016
              • 12
              • Philippines
              i think i need a full copy dumped from another motherboard that is same with mine
              • Claudiomfa
                • Nov 2015
                • 455
                • Portugal
                Do you have you original backup. If yes, please post them here
                • DBBJAF
                  • Apr 2020
                  • 5
                  • Iran
                  This is a copy of original bios , I am not sure if it's damaged or not.
                  • watanirar
                    • Dec 2018
                    • 24
                    • youssoufia
                    thank you for
                    • OnRepair1
                      • Oct 2022
                      • 33
                      • Portugal
                      Originally posted by Claudiomfa
                      try and report
                      IT works perfectly ! Thanks
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • grimacelord
                        by grimacelord
                        07-10-2025, 02:52 PM
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • skurvysyn
                        BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
                        by skurvysyn
                        laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
                        original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
                        01-08-2025, 04:45 PM
