Re: Bios needed HP 290 G2
Hi Guys, Im facing a similar issue and would appreciate any advice or help. I tried the clean bios listed earlier and the machine booted but now its not turning on again. It seems to turn on intermittently.
I have removed the Cmos battery and when I insert the power cable the fans spin and then stop and then spin again and stop and eventually just stop. If i remove and reconnect the power cable the fans will spin again but even less times until eventually reinserting the power cable shows no sign of life at all.
Does anyone have any ideas on what else could be the issue.? My original bios is attached.
Board is Lincs 17514-1 Rev.A
348.OA816.OO11
I am facing the same issue for board. What about yours ?Leave a comment:
Re: Hp 290 g2 microtower pc bios dump
Serial Number: 8CG9212MPX.Attached FilesLeave a comment:
Hello
i need bios dump for hp 290 g2 microtower
board number lincs mb
17514-1 rev .a
348.0a817.0011Attached FilesLeave a comment:
Hi. Simpler board came
HP slimline
Newark Rev.A
17520-1
348.0AC92.001
Board starts turns Off..
No display.PL40701 no power.Rest all coils have power .
It has IT8991E 128 DXS is it programmable?
Flashed bios from other site, no changes. I will try this bios from this post too.Leave a comment:
no this is not hp x360
its a slimline machine hp slim 290
mobo part no
17520-1 REV:A
348.0AC03.0011Leave a comment:
Newark Rev.A
17520-1
348.0AC92.001
here is old dump attached
plz send tested bios
thanks in advanceAttached FilesLeave a comment:
Hellow there. Ihave the same HP 290 G2. Power button blinks 3 long then 2 shot. what could be the problem. help pleaseLeave a comment:
HP slimline
Newark Rev.A
17520-1
348.0AC92.001
A similar problem with bios, there is a working dump with exactly the same pc, I can’t clean me in it, all attempts to clean me turn the device into a "brick", as well as firmware dump from the site’s siteLeave a comment:
here is EC extracted from main bios.Attached FilesLeave a comment:
Yes i tried both bios same thing.
Motherboard uses IT8991E controller , can anyone could extract Ec firmware from bios file?Leave a comment:
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
Channel: BIOS Requests ONLY!
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM - Loading...
