need ASUS ET2032IUK ET2032I REV 1.2
  • narsil
    Enas
    • Dec 2017
    • 84
    • france
    need bios
    ASUS ET2032IUK
    ET2032I REV 1.2
    asus all in one et2032i
    • 21850
    Re: need ASUS ET2032IUK ET2032I REV 1.2
    Post your bios backup .
    • narsil
      Enas
      • Dec 2017
      • 84
      • france
      No I don't have a reserve
        • 21850
        ok, try this bios.
        • narsil
          Enas
          • Dec 2017
          • 84
          • france
          ok, try this bios.
          Thank you
            • 21850
            You`re welcome .
            • BlueRay
              • Jul 2018
              • 20
              • Indonesia
              ok, try this bios.
              not working for me. did you have another bios? or anyone can repair this bios, stuck on asus logo
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • lrouw84
                Asus vivobook s510ua bios changed to x510un
                by lrouw84
                Hi there,
                I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                01-28-2023, 01:31 PM
              • ferah831208
                help with bios decompose for Asus s5506ma
                by ferah831208
                I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
                08-24-2025, 05:35 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
