Imac 2017 emc 3069 efi password
  • layad
    • Nov 2011
    • 244
    Hi , anyone has clean dump file for imac 2017 emc 3069?
  • mjalil28
    Banned
    • Oct 2015
    • 45
    Re: Imac 2017 efi password
    Upload yours i can do clean your bin without password
    • layad
      • Nov 2011
      • 244
      thank you but i made a mistake and erased the chip before doing any backup
      • layad
        • Nov 2011
        • 244
        i have this backup but i dont know it is a full dump backup or not as i was struggling reading it
        • layad
          • Nov 2011
          • 244
          thanks , i sorted it out , password is cleared now
          • kevinstone2010
            • Apr 2016
            • philippines
            i need clean bios too , can you upload yours?
            • peste
              • 13564
              • ROMANIA
              post bios backup ...
              • shani
                • Nov 2017
                • 10
                Hi Is this clean bios file, without password?
                • Buzzfuzz2k
                  Bios password removal on a Unowhy dump
                  by Buzzfuzz2k
                  Hi Everyone,
                  I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                  The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                  the Computer is a Unowhy small pc
                  N° UYM6524702229
                  After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                  My first attempt was to get the bios dump from windows...
                  11-13-2023, 07:37 AM
                • dell_bios
                  Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
                  by dell_bios
                  I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
                  The board has three SPI flash chips:
                  - W25Q64FV (main BIOS)
                  - W25Q32FV (EC/TPM)
                  - W25X10CL (configuration)
                  I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
                  The dump contains protection that needs to be removed.
                  If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
                  I’m also happy to share my dump for comparison if needed.
                  Laptop model: [please specify, e.g....
                  10-16-2025, 04:28 PM
                • mon2
                  In search of T2 rom dump for iMAC 2017 A1862
                  by mon2
                  Hello all. Have an imac that is not able to create PP1v8_S5 and there are no shorts on the rail. Unable to DFU due to USB not working. Suspecting corruption of the T2 firmware.
                  Welcome all suggestions. Thanks.
                  08-13-2024, 08:13 PM
                • iZakre
                  HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                  by iZakre
                  Hello everybody!
                  To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                  The thing is that I had installed TeamViewer and could log into the computer...
                  02-19-2023, 02:27 PM
                • boheman
                  Apple iMac 820-01061 A EMC 3069 2017 21.5
                  by boheman
                  Hi!
                  I'm looking for any experience about 2017 iMac with random shut down.
                  It's a working one but only I can use for 4-5 minutes, after shut down and cannot turn it again. But I tried it a few days later (5-6 days) and it works, and after 4-5 minutes crashed again.
                  All of the voltages fine on the board, and no visible damage or burned components or water damage. No shorts to the ground.
                  I replaced a couple components to find the problem: PSU, CPU, RAM, RTC battery, BIOS.
                  Only I find LCD backlight fuse dead caused by bad LCD cable, I replaced it...
                  01-29-2023, 08:18 AM
