Asus H55M-LX desktop motherboard schematics
  • lazyboi11
    • Dec 2014
    • 12
    • Philippines
    Good day everyone..
    Can I ask for schematics of this motherboard.
    Problem is when I turn on the computer, It powers up then off, then powers up then off again..This loop goes on continuously until I press the power button..
    It seems that the BIOS is corrupted but unluckily, I have no programmer at the moment..
    Thanks in advance..
  • lezsimply
    Low resistance reading on 3v line, Asus Prime H310M-A R2.0 desktop motherboard
    by lezsimply
    Hello Everyone and Good Day,
    I've got an issue with this desktop motherboard. It does not power on, Asus Prime H310M-A R2.0. I tested 33ohms reading on 3v line on the ATX connector. It beeps on continuity mode. I tried injecting voltage from 0.9v at 1.5amps and no current being drawn. I raised the voltage to 3v @ 4amps and now I only get 22mA on current. I checked with thermal camera and there is no part heating up. I'm afraid of going further the safe voltage. What could possibly causing the line to be shorted. 5vsb has no short. I get 0.9v on positive pin of power switch. There's...
    11-22-2024, 03:14 AM
  • glovecaps
    by glovecaps
    11-25-2024, 04:23 PM
  • dhenion
    Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
    by dhenion
    I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
    The original board was:
    ASUS X510UNR REV 3.0 A
    The replacement board is:
    ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
    It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
    01-30-2024, 01:45 PM
    ASUS P5GC-MX motherboard recap
    by momaka
    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
    So here is what the motherboard looked like with its original caps:
    CPU VRM area up close…...
    01-27-2021, 11:59 PM
  • MakNCheese
    ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
    by MakNCheese
    I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
    Symptoms:
    • Severe lag across the system, including BIOS navigation.
    • Slow boot times and unresponsive performance in Windows.
    • Battery charges very slowly (e.g., ~5% in 2–3 hours).
    • No error messages or BSODs, just extreme sluggishness.
    What I've Tried:
    • Replaced
    06-04-2025, 12:48 AM
