Bios For Lenovo All In One C20-00.(LA-C671P)
Re: Bios For Lenovo All In One C20-00.(LA-C671P)
Give this file a try and post feedback.Attached FilesComment
Hello All,
I didnt have the 1.8 volt adapter, got it today, I have the CH341A black version and tried with multiple programmers, end result is that the chip doesn't verify once the program is written on it..
:-( i am back to where i was stuck
PS the EC bios was successful
Do guide if anyone knows what to do...
Error Code: Current programmer: CH341
20:06:23
Verify memory...
Verification error on address: 00000000
Execution time: 00:00:00.060Comment
Every donation made will go towards server fees and maintenance costs.Comment
Thank you very much, I already followed the steps but at the time of writing the new .bin file it tells me that the file size is larger than the chip sizeComment
Try NeoProgrammer software - https://www.badcaps.net/forum/attach...7&d=1626459940Comment
Hi. I would like to ask you for some help. I have right now a Lenovo C20-00 F0BB00GGLD. This pc was having an error with an USB port, when i tryed to access the Bios there was a password, wich is rare. Decided to reinstall the Bios file via windows lenovo installer but when the pc started up i had only a black screen, no mouse, keyboard and nothing else but fan noise and the start button led. I have indentified two memmory chips one is MX25U6435F 64Mbit chip with a 8MB file on it and a smaller 128K Winbond 25X10CL which i suppose is the EC. The 8MB .BIN you can extract it from the lenovo .exe file but no EC .BIN to be found anywhere. I bought the CH341A and rewrote the MX25U6435F which was the only one with enough capacity so it had to be the main Bios. It was the same, no video, no ports, nothing just the fan and led. I'm stuck, two weeks and no progress. Do you have some experience with this kind of hardware? Maybe the EC needs rewriting with the files posted in the forum? or maybe is something else?
Thanks!Last edited by Marasmo; 01-08-2022, 10:55 PM.Comment
Decided to install the C20-00 .bin posted earlier and it worked. I'm sure i have installed the right BIN for the Lenovo F0BB00GGLD but now i'm sure it was a corrupt file. Now i have a different machine ID and serial number (obviously a .bin from another c20 model) but i don't care. I'm investigating if serial and model # can be changed without using the Lenovo Bios tool . Thanks a lot to the contributors.Last edited by Marasmo; 01-09-2022, 10:12 PM.Comment
by DiddiAbRecently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...-
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... - Loading...
