want bios for dell optiplex 755 4mega
  • mohammed aram
    • Apr 2015
    • 74
    • egypt
    hi
    want bios for dell optiplex 755 4 mega
    the bios file on dell site 1 mega and the original file 4 mega
    so i want 4 mega bios file
    thanks in advance
  • Me.Orouji
    • Dec 2015
    • 117
    • Iran
    Re: want bios for dell optiplex 755 4mega
    Try this
    • mohammed aram
      • Apr 2015
      • 74
      • egypt
      Originally posted by Me.Orouji
      Try this
      thank you
      i found it and tested ok
      i will upload it
      • mido000
        • Feb 2017
        • Egypt
        nice
        • Joseps
          • Jan 2021
          • Spain
          Try this
          I am a few years late to this post, but I want to thank you for the file. I've been able to finally fix my 755usff that went bricked long time ago after a failed update.
          To anyone dealing with this Winbond W25X32 flash, I was unable to make it work in Windows with the stock software, neither with my new EZP2019+ programmer, nor my old CH341A (also ASProgrammer failed too in this one)
          The only way I managed to make it work was using flashrom, in my setup using a Debian virtual machine in VMware workstation's Win10 host.
          The clamp failed all the time but desoldering the chip worked like a charm.
          Thank you very much for the .bin file.
          Two roads diverged in a wood, and I—
          I took the one less traveled by, And that has made all the difference.
          • I89or
            • Jul 2025
            • Russian
            Hi. What motherboard do you have in your destop?
            • I89or
              • Jul 2025
              • Russian
              Try this
              Hi, can you tell me from which motherboard you gave the BIOS in this message?
              • mrrubik
                Dell Optiplex 7010 micro bad BIOS flash?
                by mrrubik
                Hi folks,
                I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                Steps I took:
                1. Read BIOS with CH341a, verified hash twice
                2. Patched
                12-23-2024, 04:11 PM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
              • capoplays
                Help with BIOS update on Dell G15 5515 after chip replacement
                by capoplays
                Hey everyone,
                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                When I check the BIOS using the F12 menu Flash...
                Yesterday, 06:53 AM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
