need bios for 820-2507-A A1312 (EMC 2309)
  • rookieme
    • Oct 2014
    • 399
    • Greece
    I need a working bios in order to test my no power on problem.
    Thank you
  • techman1025
    • Jun 2014
    • 497
    Re: need bios for 820-2507-A A1312 (EMC 2309)
    Hi
    Here is a working file and you could use it for testing ..but it will be dirty Me region to leave in you will have problem's so after if you need it fixed upload your original file and i will do it all for you even SSN#
    Techman1025
    • cyberhack
      • Feb 2013
      • 466
      • Uk
      Have a look here to help
      How to Set a Clean ME Region in Apple EFI
      https://ghostlyhaks.com/blog/apple-e...lean-me-region
      • GIFixed
        • Sep 2019
        • 61
        • Denmark
        EMC 2309 A1312 Core2 Duo does NOT have ME region?
        It is not EFI?
        If you drop the BIOS bin file on ME analyzer, it says: "File does not contain Intel Engine firmware"
        If it really does have ME region and ME firmware, how do we clean ME region in this model?
        • piernov
          • Jan 2016
          • 4439
          • France
          No there's no ME region on Core 2 Duo machines, no need to clean it. You only have to change serial number and fix Fsys checksum.
          • pulgagr
            • Aug 2018
            • usa
            Can someone help me cleaning the password firmware from this file?
            It is a iMac A1312 EMC 2309.
            • piernov
              • Jan 2016
              • 4439
              • France
              Change RAM configuration and do 3x PRAM reset.
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • Lexsmash85
                Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
                by Lexsmash85
                Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
                Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
                USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
                08-06-2025, 03:41 AM
                by Vesko356
                08-11-2023, 03:27 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
