Anyone have a BIN file from this model?
HP P7 Desktop - MS-7778 V1.0 Bios Dump Needed
Re: HP P7 Desktop - MS-7778 V1.0 Bios Dump Needed
backup your bios and try this
if it does not work, post your backupAttached FilesIm Back... sort of... -
Right after posting this, I found a JAS_8052.BIN.
The HP had a Winbond 25Q64FVSIG which was bad. I managed a backup from it, but don't think I would trust it. As it failed while trying to write the new bin repeatedly.
Located a donor FV chip from an Asus board. Erased it, and wrote the JAS_8052 successfully.
HP desktop is now up and running. Here is the bin I used.Attached FilesComment
The only side note ...
Looking at "System Information" in the bios ... its blank. Where you would normally see information like model number, hp sku number, etc ... those entries are blank.
Does HP tattoo these things with that info? Seems I recall something along those lines.Comment
Been several years since I messed with changing that info. Doesn't display an HP logo either at power on. But who cares about that? LoL
Think I'll just leave it be. Computer is running fine and customer wants it back today. Windows activation is good. I half expected to have some product key issues.Comment
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
Channel: BIOS Requests ONLY!
by vinaypundithI have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
So, I'm looking for a BIOS dump for this machine - a 16MB one....-
I badly need bios dump for HP DM1-4000er,
Model: HP DM1-4000er
Motherboard: DA0NM9MB6D0 REV.D
Product: QJ490EA#ACB
Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
- Loading...
