HP P7 Desktop - MS-7778 V1.0 Bios Dump Needed
  • katfish
    • Jul 2016
    • 76
    Anyone have a BIN file from this model?
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: HP P7 Desktop - MS-7778 V1.0 Bios Dump Needed
    backup your bios and try this
    if it does not work, post your backup
    Im Back... sort of...
    • katfish
      • Jul 2016
      • 76
      Right after posting this, I found a JAS_8052.BIN.
      The HP had a Winbond 25Q64FVSIG which was bad. I managed a backup from it, but don't think I would trust it. As it failed while trying to write the new bin repeatedly.
      Located a donor FV chip from an Asus board. Erased it, and wrote the JAS_8052 successfully.
      HP desktop is now up and running. Here is the bin I used.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        Great. Another cas of faulty eprom. Glad to hear its working now
        • katfish
          • Jul 2016
          • 76
          The only side note ...
          Looking at "System Information" in the bios ... its blank. Where you would normally see information like model number, hp sku number, etc ... those entries are blank.
          Does HP tattoo these things with that info? Seems I recall something along those lines.
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            Nbdmifit or something like that. Link is somewhwrmere is on forum here. Try that
            • katfish
              • Jul 2016
              • 76
              Been several years since I messed with changing that info. Doesn't display an HP logo either at power on. But who cares about that? LoL
              Think I'll just leave it be. Computer is running fine and customer wants it back today. Windows activation is good. I half expected to have some product key issues.
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                If you post your nackup *maybe* i could copy info to new bios with hex editor... works most of the time
                • katfish
                  • Jul 2016
                  • 76
                  Customer picked up already. :P Thanks for the offer though.
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • TacticalFahrrad
                    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                    by TacticalFahrrad
                    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                    06-30-2025, 04:09 AM
                  • vinaypundith
                    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                    by vinaypundith
                    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                    So, I'm looking for a BIOS dump for this machine - a 16MB one....
                    08-03-2024, 12:32 PM
                  • James Maxwell
                    HP DM1-4000er Bios Dump needed
                    by James Maxwell
                    I badly need bios dump for HP DM1-4000er,
                    Model: HP DM1-4000er
                    Motherboard: DA0NM9MB6D0 REV.D
                    Product: QJ490EA#ACB
                    Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                    10-28-2024, 05:38 PM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
