Trying to find 3v and 5v regulators without schematics... Could it be this IC?
  • mattpd
    • Oct 2012
    • 301
    I have a board that is missing 3v and 5v standby power. I also have a working board to compare. Board is AMPKB-CT which is from an HP all-in-one, but is basically like a laptop board I think. No schematics to be found.
    I have googled every IC part number I can find and none of them are 3v or 5v regulators.
    There are a few 20 pin ICs that could be it, but I am not sure. They are grouped together with a coil, cap, and mosfets, so it looks like they may be regulators. See attached picture.
    "7A FD" is what is inscribed. On the other board says it says "7A FC" so I think the "FC" and "FD" are not part of the partnumber.
  • dellxps15
    • Feb 2014
    • 1585
    • italy
    Re: Trying to find 3v and 5v regulators without schematics... Could it be this IC?
    generally 3.3 and 5 volt is a 24 pin 6x4 and is near 2 little inductor. post whole board picture.
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      I think you have correct track, its regulator DC/DC for 3.3v/5v
      here:
      https://cdn.badcaps-static.com/pdfs/...6efd1981b0.pdf
      • mattpd
        • Oct 2012
        • 301
        here:
        Perfect!
        What was your process to locate this part online? Or did you just know already?
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          No, I didn't know, from what dellxps15 mention above.
          - trying to find at aliexpress image of mobo AMPKB-CT
          - searching in "Richteck marking information code" document for notebook with word 7A
          https://www.badcaps.net/forum/showthread.php?t=39126
          • mattpd
            • Oct 2012
            • 301
            Thanks for the good info.
            I found 19v VIN on this chip on the good board. No VIN or EN on the bad board.
            Without schematics I am kind of lost, but I will try to track down why VIN is missing. I can see 19v on other parts of the bad board. Any idea?
            • mattpd
              • Oct 2012
              • 301
              I figured it out.
              RT8243 was short to ground on VIN pin and a 2.2ohm resistor next to it was open. Replaced both with parts from the good board and it works.
              Thanks again.
              • mohamedalepgig
                • Nov 2014
                • 6
                • egypt
                Yes you are right also I think 8a also is 8243a regulator for 3.3 , 5
                • alas3376
                  • Nov 2011
                  • 382
                  • BENIN
                  it's a TPS51219 find its datasheet and check
                  • xmen9004
                    • Jul 2015
                    • 12
                    • México
                    thanks for the information
                    • 1fg52
                      • Apr 2021
                      • 6
                      • Colombia
                      Looks like a common problem. Thanks to this thread i found standby voltages went to zero but in my case short circuit is in one rail and Vin got cut (looks from a burn fuse or some copper got kaput). Can be anything downstream and i don't have a thermal camera.
                      • 1fg52
                        • Apr 2021
                        • 6
                        • Colombia
                        I forgot to mention I desoldered the 3.3v inductor and jumped Vin from the power brick connector to Vin in RT8243 and got 5 and 3.3v standby voltages.
                        My only problem now is 3.3v rail shorted to grownd :v
                        • Vesko356
                          by Vesko356
                          08-11-2023, 03:27 AM
                        • yuii
                          ThinkPad W530 - faulty CPU regulators?
                          by yuii
                          Hello
                          I've got two W530 boards, one with K1000M and one with K2000M graphics card. The first one had an issue of turning off under heavy CPU load after about 30 minutes or in idle. GPU load wasn't causing it to shut down. Trying to turn it back on would only make the power LED to come up for about 2 seconds without fan spin or thinklight flash, and that's it. It also wasn't charging the battery after it died.
                          Gently pressing the laptop in left upper corner would fix this problem for a couple of days.
                          The latter is completely dead and has the same 2-second power blink, nevermind...
                          11-01-2023, 02:59 AM
                        • corrize
                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                          by corrize
                          Hello, I search this connector (oxydated).
                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                          Do you know how to find this connector please ? What is the exact name for find it ?
                          08-06-2024, 05:25 PM
                          Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                          by sam_sam_sam
                          This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                          Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                          07-07-2024, 02:34 PM
                        • temyth
                          Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
                          by temyth
                          Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
                          The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
                          01-07-2024, 04:50 PM
