Request: Beelink Gemini M BIOS dump (SN 4125HOLH70514 – Winbond 25Q128FW)
  • Max74747
    • Oct 2025
    • 5
    • France
    I’m looking for a verified BIOS dump for a Beelink Gemini M mini-PC.
    The device is now bricked after flashing the official BIOS file from Beelink’s website (M41N100_1018_GeminiM8G36.bin).
    Details:
    Model: Gemini M-H-8128QD0W64PRO
    CPU: Intel Celeron J4125 (Gemini Lake Refresh)
    Serial number: 4125HOLH70514
    BIOS chip: Winbond 25Q128FW (8-pin SPI, 3.3 V)
    Symptom: Power LED and fan run, but no HDMI output after flash.
    If anyone has a working dump (.bin) for this revision, or can share a known good image, I’d really appreciate it.
    Thanks in advance
  • peste
    • Dec 2016
    • 13550
    • ROMANIA
    Details:
    Thanks in advance
    post the contents of the bios chip even if it is corrupted..
    • Max74747
      • Oct 2025
      • 5
      • France
      • Dump file: GeminiM_dump_bricked.bin (~16 MB)
      • SPI chip detected: Winbond W25Q128FW (1.8V), SPI ID EF6018.
      • Programmer: CH341A (with 1.8V adapter + SOIC8 clip).
      • Tool used: NeoProgrammer.
      • CRC32 of dump (NeoProgrammer): 0xFC9D3793.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12314
        Hope is right
        • Max74747
          • Oct 2025
          • 5
          • France
          Hi hoaca388,
          Thanks a lot for sharing the M41N106.bin file — I really appreciate your help.
          I’ve just flashed it successfully (erase → program → verify all OK), but unfortunately the system still shows the same symptoms:
          power LED and fan turn on,
          but no HDMI signal, no POST, no keyboard response.
          It seems this BIOS might not match my exact board revision (AZW Gemini M Ver:4.1, Winbond W25Q128FWSQ).
          If you or anyone else has a dump from the same revision, I’d be happy to test it.
          Thanks again for your time and support!
          — Maxime
            • 21840
            Hi hoaca388,
            — Maxime
            Beelink support have three different bios versions for the Gemini M series https://dr.bee-link.cn/?dir=uploads%...ies%2FGEMINI-M ,did you try the other two ?
            • Max74747
              • Oct 2025
              • 5
              • France
              Yes, I’ve just tried the other two BIOS files from the Beelink repository — unfortunately, none of them worked.
              I’m currently in contact with Beelink support and waiting for their R&D team to provide the correct BIOS for my Gemini M Ver 4.1 (Winbond W25Q128FWSQ).
              In the meantime, I’ve managed to find another working Gemini M unit with the same specs, and I’ll dump its BIOS to compare and possibly restore the bricked one.
                • 21840
                Post the backup of the other working unit, it will need the TXE/ME firmware cleaning.
                • Max74747
                  • Oct 2025
                  • 5
                  • France
                  Here is the full dump from the working Gemini M unit (same Ver 4.1 board, Winbond 25Q128FWSQ).
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • hyperwood
                    [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                    by hyperwood
                    I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                    The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                    I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                    ✅ What I need:
                    • A working 2MB BIOS dump
                    • Matching NM-E471 Rev. 2.0, e.g. JY575
                    06-25-2025, 02:28 PM
                  • spmetroil
                    Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                    by spmetroil
                    I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                    The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                    I have a CH341A programmer and I already attempted the following steps:
                    1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                    2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                    3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                    08-19-2025, 09:23 AM
                  • TechMark1
                    Alienware 17 Area-51m laptop BIOS dump with Winbond 25Q80DVSIG
                    by TechMark1
                    I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted. I just zipped it so I could attach it....
                    09-21-2025, 03:36 PM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
