BIOS on an Asus Prime H310M-E R2 motherboard
This topic has been answered.
  • Pedro Ramírez
    • Jul 2024
    • 21
    • Chile
    Hi friends, I need help with the BIOS on an Asus Prime H310M motherboard - E R2, no video when turned on. I've attached the original backup.
  • Answer selected by Pedro Ramírez at 08-01-2025, 09:31 PM.
    noname2024
    • Aug 2024
    • 295
    • CỎ MỸ XỊN
    bios
    • meatwar
      ...just Member
      • Feb 2020
      • 26
      • PRT
      You can use any Asus bios update file as they are complete SPI images, for SPi programmer remove initial 0x800 data block, FD44editor for original board data transfer present in dump file.
      • Pedro Ramírez
        • Jul 2024
        • 21
        • Chile
        Hello, nice to meet you. Thank you for your interest in helping. Honestly, I'm still not familiar with editing the BIOS. I'm just learning. But with this BIOS, I don't know why the editing is failing.
        • m1ch43lzm
          • Mar 2019
          • 1087
          • Peru
          Try this, it's latest version 2209 from ASUS website, ready to flash with programmer
          Remove from 000 to 7FF with hex editor, or open .cap with UEFITool, expand "AMI Aptio capsule", right click on "Intel image" -> Extract as is...
          I copied manually from 354000-35405F and 370090-3700CF from your backup to this BIOS
          • Pedro Ramírez
            • Jul 2024
            • 21
            • Chile
            Dear colleagues, I haven't been successful editing the BIOS. I've followed the steps, but I may be doing something wrong or missing a step. The new file matches the motherboard data with the backup file, and they're the same size. I program, but I still don't have an image.
            • m1ch43lzm
              • Mar 2019
              • 1087
              • Peru
              Check with known good 8th/9th gen/Pentium G54xx CPU with integrated graphics (check CPU support list) and known good RAM
              Inspect for bent/damaged pins on CPU socket
              First boot may take few minutes
              Have you tried with my BIOS? It's ready to program, size is 16777216 bytes
              Desktop motherboard BIOS are easy, on ASUS you have to cut first 000-7FF with hex editor, or extract the .cap with UEFITool
              https://www.asus.com/latin/motherboa...E-H310M-E-R2-0
              If that doesn't work you may have a hardware problem
              • noname2024
                • Aug 2024
                • 295
                • CỎ MỸ XỊN
                bios
                • Pedro Ramírez
                  • Jul 2024
                  • 21
                  • Chile
                  Dear colleague, thank you all for your help. The motherboard is now working.
                  • ramrk
                    • Feb 2019
                    • 155
                    • India
                    Originally posted by noname2024
                    bios
                    thanx working fine
                    • glovecaps
                      by glovecaps
                      11-25-2024, 04:23 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • oragano
                      ASUS ex-b250-V7 motherboard bios corrupted - by me
                      by oragano
                      hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                      So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                      i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                      10-17-2024, 02:53 AM
                      Asus PRIME H310M-K Motherboard Board View
                      Asus PRIME H310M-K Motherboard Board View...
                      10-03-2024, 10:09 AM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
