ASROCK H310CM-DVS rev 1.01 BIOS Request. Corrupted bios.
  • ashr88
    • Mar 2023
    • 59
    Hello, I have no post but it powers. All power rails are present. Could somebody help me with this? Thank you.
    Serial number: E2XMUA037552
    • 20848
    Get one from ASRock support https://www.asrock.com/mb/Intel/H310CM-DVS/#BIOS
    • ashr88
      • Mar 2023
      • 59
      Thanks, I didn't think it would be as easy as that.
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • trepachka
        Corrupted BIOS rebuild request for HP 17-cn1008cy
        by trepachka
        I have this HP 17-cn1008cy laptop with corrupted BIOS. On boot the message comes up and states that BIOS is corrupted.
        Normally, I would download the bios file from HP website but for some reason their software does not run when clicked on it (winflash.exe file). So, I need your help.
        S/N: 5CG1425NHD
        ProdID: 552Y1UAR
        BIOS file is attached. Thank you....
        05-05-2024, 03:01 PM
