Corrupted BIOS rebuild request for HP 17-cn1008cy
  • trepachka
    • Oct 2022
    • 429
    I have this HP 17-cn1008cy laptop with corrupted BIOS. On boot the message comes up and states that BIOS is corrupted.
    Normally, I would download the bios file from HP website but for some reason their software does not run when clicked on it (winflash.exe file). So, I need your help.
    S/N: 5CG1425NHD
    ProdID: 552Y1UAR
    BIOS file is attached. Thank you.
  • minhdigital
    • Nov 2022
    • 756
    • Vietnam
    S/N: 5CG1425NHD
    ProdID: 552Y1UAR
    Send to you
    • trepachka
      • Oct 2022
      • 429
      Computer is working now. Thank you.
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
      • Sebastian Codrean
        BIOS file for ASUS F542UN laptop
        by Sebastian Codrean
        Hello to all of you! I need help with a BIOS file.
        The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
        So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
        02-20-2025, 10:25 AM
      • Fr33man
        BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
        by Fr33man
        I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
        *Novo button power on
        *Disconnected internal battery...
        09-23-2024, 01:16 PM
      • Loli Popu
        DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
        by Loli Popu
        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
        12-13-2024, 08:29 AM
      • iZakre
        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
        by iZakre
        Hello everybody!
        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
        The thing is that I had installed TeamViewer and could log into the computer...
        02-19-2023, 02:27 PM
