ASUS PRIME-H310-PUS TESTED BIOS
  • mui
    • Nov 2023
    • 6
    • Tanzania
    here is ASUS PRIME-H310-PUS TESTED BIOS i have been facing 1 long beeps,4 short beeps
    • 31260
    One Long Four Short Beeps
    cpu-temperature-beep-codes
    A hardware component failure, for example, the CPU fan, triggers this specific type of beep code. Besides this CPU reaching extreme temperatures or the CPU getting over voltage could also cause the motherboard to give such an error message.
    To fix this, we recommend that you perform the following steps to stop the beep error codes.
    Lower high CPU usage
    Change thermal paste
    Reseat CPU fans
    so asus says
    • mui
      • Nov 2023
      • 6
      • Tanzania
      thanks but i fixed it by writting new bios file
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
