ASUS PRIME H610M-A D4 Bios
  • narou21
    • May 2018
    • 9
    • alger
    hi , i need a bios for ASUS PRIME H610M-A D4 dump
    thanks
  • noname2024
    • Aug 2024
    • 256
    • CỎ MỸ XỊN
    thanks
    PRIME-H610M-A-D4-ASUS-3601
    • narou21
      • May 2018
      • 9
      • alger
      thanks noname2024​ file worked 10/10
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
