Asus M5A78L-M LX3 BIOS Request
  • Schwarzemann
    • Sep 2024
    • Turkey
    Does anyone have a BIOS dump for M5A78L-M LX3 motherboard? Please help.
    post moved..
  • peste
    • 12887
    • ROMANIA
    post moved..
    post S/N, full name and model, post the contents of the bios chip even if it is corrupted..
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • skurvysyn
      BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
      by skurvysyn
      laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
      original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
      01-08-2025, 04:45 PM
