Hello all, I know it's a desktop, but this forum is way more active than the others. Motherboard is DH57M01. Thank you.
BIOS dump for Studio XPS 8100
Tags: None
Re: BIOS dump for Studio XPS 8100
Thank you, but that's not the full dump, it's 8MB, I already have that file from Dell downloads.Comment
I did it, I copied over the data with HxD finding matching offsets. Version got updated to A05. I attach dump for future reference, Service Tag field is empty.Attached FilesComment
orientalsniper
Thank you, Thank you, Thank you, Thank you, Thank you and many more thanks.
the file you uploaded above saved my xps 8100 from the scrap heap or at least saved me from having to buy a new board after a bad flash
the bad flash itself was probably caused by the two bulging 470uf capacitors I found positioned between the cpu and the pcie slot.
all fixed now
Thanks again.
DarcyComment
thanks
reserve bad update
6502 from dell web siteAttached FilesLast edited by chaker752000; 09-03-2018, 07:26 AM.Comment
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
