BIOS dump for Studio XPS 8100
  • orientalsniper
    • Apr 2013
    • 461
    Hello all, I know it's a desktop, but this forum is way more active than the others. Motherboard is DH57M01. Thank you.
  • kotnatan
    Banned
    • Apr 2014
    • 181
    • Ukraine
    Re: BIOS dump for Studio XPS 8100
    s8100-a05
    • orientalsniper
      • Apr 2013
      • 461
      Thank you, but that's not the full dump, it's 8MB, I already have that file from Dell downloads.
      • orientalsniper
        • Apr 2013
        • 461
        I did it, I copied over the data with HxD finding matching offsets. Version got updated to A05. I attach dump for future reference, Service Tag field is empty.
        • darcy
          • Jul 2016
          • scotland
          orientalsniper
          Thank you, Thank you, Thank you, Thank you, Thank you and many more thanks.
          the file you uploaded above saved my xps 8100 from the scrap heap or at least saved me from having to buy a new board after a bad flash
          the bad flash itself was probably caused by the two bulging 470uf capacitors I found positioned between the cpu and the pcie slot.
          all fixed now
          Thanks again.
          Darcy
          • mhawryl
            • Mar 2017
            I managed to extract and mod the A05 bios for the Studio XPS 8100, but I can't get it to write to the motherboard.
            How do you write a modded BIOS to this system?
            Thanks.
            • alexsilvertown
              • Feb 2016
              Hi. Help pls with bios dump for XPS 8300 , DH67M01 mobo.
              • chaker752000
                • Mar 2016
                • 47
                • tunis
                Hi. Help me please bios dump xps 8300 dh67m01 4mb
                  • 21841
                  Post your bios backup .
                  • chaker752000
                    • Mar 2016
                    • 47
                    • tunis
                    my bios with bad updates
                    this is ori from dell web site
                    • chaker752000
                      • Mar 2016
                      • 47
                      • tunis
                      thanks
                      reserve bad update
                      6502 from dell web site
                      • chaker752000
                        • Mar 2016
                        • 47
                        • tunis
                        Re: BIOS dump for Studio XPS 8300
                        xps 8300 thanks
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • mkdj
                          by mkdj
                          Dear all,
                          10-19-2025, 04:41 AM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          by haitham sharabati
                          Hello engineers 😀,
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          💀 Problem:😅
                          08-07-2025, 04:54 AM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
