ASUS PRIME B365M-A DESKTOP MOTHERBOARD BIOS HELP
This topic has been answered.
  • dnytwaryors
    • Aug 2023
    • 47
    • Philippines
    Hello Everyone, Can you help me clean this bios backup I have? It won't display. I'll try everything related to display and my last option is bios, Thank you.
    This is my backup bios
  • Answer selected by dnytwaryors at 08-27-2024, 08:41 PM.
    SoporteNetFe
    • Aug 2021
    • 116
    • Argentina
    You can download bios from asus and use cap to bin tool...
    • SoporteNetFe
      • Aug 2021
      • 116
      • Argentina
      • dnytwaryors
        • Aug 2023
        • 47
        • Philippines
        May I ask sir where I can download the tool?
        • hoaca388
          Badcaps
          • Jan 2022
          • 11773
          UEFI Tool. Open bios file , We see "Ami captio capsule". Right click, select "Extract body.."
          • dnytwaryors
            • Aug 2023
            • 47
            • Philippines
            Thank you sir. I already solved the problem. Converting CAP file to BIN file.
            • glovecaps
              Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
              by glovecaps
              I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
              My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
              The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
              11-25-2024, 04:23 PM
            • Pedro Ramírez
              BIOS on an Asus Prime H310M-E R2 motherboard
              by Pedro Ramírez
              Hi friends, I need help with the BIOS on an Asus Prime H310M motherboard - E R2, no video when turned on. I've attached the original backup....
              07-29-2025, 04:18 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • oragano
              ASUS ex-b250-V7 motherboard bios corrupted - by me
              by oragano
              hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
              So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
              i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
              10-17-2024, 02:53 AM
