ASUS PRIME B365M-A DESKTOP MOTHERBOARD BIOS HELP
This topic has been answered.
  • dnytwaryors
    • Aug 2023
    • 54
    • Philippines
    Hello Everyone, Can you help me clean this bios backup I have? It won't display. I'll try everything related to display and my last option is bios, Thank you.
    This is my backup bios
  • Answer selected by dnytwaryors at 08-27-2024, 08:41 PM.
    SoporteNetFe
    • Aug 2021
    • 121
    • Argentina
    You can download bios from asus and use cap to bin tool...
    • SoporteNetFe
      • Aug 2021
      • 121
      • Argentina
      • dnytwaryors
        • Aug 2023
        • 54
        • Philippines
        May I ask sir where I can download the tool?
        • hoaca388
          Badcaps
          • Jan 2022
          • 12346
          UEFI Tool. Open bios file , We see "Ami captio capsule". Right click, select "Extract body.."
          • dnytwaryors
            • Aug 2023
            • 54
            • Philippines
            Thank you sir. I already solved the problem. Converting CAP file to BIN file.
            • glovecaps
              by glovecaps
              11-25-2024, 04:23 PM
            • Pedro Ramírez
              BIOS on an Asus Prime H310M-E R2 motherboard
              by Pedro Ramírez
              Hi friends, I need help with the BIOS on an Asus Prime H310M motherboard - E R2, no video when turned on. I've attached the original backup....
              07-29-2025, 04:18 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • oragano
              ASUS ex-b250-V7 motherboard bios corrupted - by me
              by oragano
              hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
              So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
              i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
              10-17-2024, 02:53 AM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
