HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
  • hoaca388
    Badcaps
    • Jan 2022
    • 12423
    Originally posted by ronald30
    I have 2 BIOS locked HP PC's from an auction
    I dumped the BIOS and tried unlocking but the RCUnlocker procedures failed because it's a 32mb bios
    Could someone please unlock the bios dump for both PCs?
    Thank you
    PC1:
    HP ProDesk 400 G6 DM
    Serial number: 8CC0473C90
    Product number: 9AG50AV
    PC2:
    Serial number: 8CC0473CG6
    PC1_backup_8CC0473C90
    HP ProDesk 400 G6 Desktop Mini PC
    Serial_8CC0473C90
    Product_9AG50AV
    Build Id_20WWQ6AT601#SABH#DABH
    Fearture byte_3E3X476J6S6b7B7J7M7Q7T7W7maBapaqaubhcAdUdpdqfAfPk8mE.mg
    PC2_backup_8CC0473CG6
    Serial_8CC0473CG6
    Product_9AG50AV
    • beBoss
      • Mar 2023
      • 29
      Thank you
      PC1:
      PC2:
      Hey, can you tell me how you succeeded with this to read the chip and then to dump it?
      Do you mind to show me photos of your programmer, cables, how you read it, the software and where you downloaded it from, literally everything?
      I am struggling to read it with two different programmers and cables orders (I was like sure that I have matched the cables cuz mine is with 16 pins... pff) and no luck.
      i will really appreciate it, thanks!
      • Ben Sun
        • Feb 2025
        • 6
        I am have a similar problem. I have HP ProDesk 400 G6 DM.
        Serial Number: MXL2083TCW
        Product Number: 9AG51AV
        The BIOS is locked and I would like to update it. I've bought a CH431A programmer, a 16pin clip and IC clamps. Using Netprogrammer and AS programmer, I cannot get the chip to read out. I've tried a number of things but including using the IC clamps rather than the clip. I have a number of questions, if anybody has a few moments I could use the help and would greatly appreciate any advice.
        * Should the PC be plugged in when I am reading the BIOS?
        * Netprogrammer doesn't detect the IC and when selecting the chip there is number of variants for W25Q256, mine is W25Q256JVFQ. Is there a significant difference between the sub types? Do I need additional files in the programmer to read out and write back the data?
        * I've looked the data sheet and found a post that matches the pins from 16 to 8. Is the mapping correct?
        BIOS Chip Pin 2 (VCC) -> CH341a Programmer Pin 8 (VCC)
        BIOS Chip Pin 10 (VSS) -> CH341a Programmer Pin 4 (VSS)
        BIOS Chip Pin 7 (CS#) -> CH341a Programmer Pin 1 (CS)
        BIOS Chip Pin 8 (SO / IO1) -> CH341a Programmer Pin 2 (MISO)
        BIOS Chip Pin 15 (SI / IO0) -> CH341a Programmer Pin 5 (MOSI)
        BIOS Chip Pin 16 (SCLK) -> CH341a Programmer Pin 6 (SCK)
        BIOS Chip Pin 9 (IO2) -> CH341a Programmer Pin 3 (WP)
        BIOS Chip Pin 1 (IO3) -> CH341a Programmer Pin 7 (HOLD)
        * I don't have another computer with a compatible BIOS chip (thinking about buying a chip to debug the programmer). Is there anything I am missing to debug the CH431A?
        Thank you in advance for any assistance.​
        • hoaca388
          Badcaps
          • Jan 2022
          • 12423
          * Should the PC be plugged in when I am reading the BIOS ?
          No , all power sources must be isolated from the motherboard.
          * Netprogrammer doesn't detect the IC and when selecting the chip there is number of variants for W25Q256, mine is W25Q256JVFQ. Is there a significant difference between the sub types? Do I need additional files in the programmer to read out and write back the data ?
          ​Since I don't use CH341A, I'm not sure but CH341A is the cheapest but not the best.
          • Ben Sun
            • Feb 2025
            • 6
            I managed to download the BIOS. Can somebody help me remove the admin password? Many thanks in advance!
            • hoaca388
              Badcaps
              • Jan 2022
              • 12423
              #26
              Serial _MXL2083TCW
              Product_9AG51AV
              Build Id_20WWQ6ET601#SABA#DABA
              Fearture byte_3E3X475K6J6b7B7J7M7Q7T7W9AaBapaqaubhcAdUdpdqfAfPk8mEnV.qQ
              • Ben Sun
                • Feb 2025
                • 6
                Thank you for the response! I really appreciate it! Sadly, I've tried flashing that bin to the computer and it refused to boot. Afterwards, I flashed back the old bin and it started up with the password as before. In addition, I've also tried following some tutorials and downloaded a clean CSME 14.1, placed it into the region and regenerated the image. The resulting image also didn't remove the BIOS password. If at all possible, could you take another look?
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12423
                  #28
                  Clear ME FILE
                  • Charlie Daniel
                    • Feb 2025
                    • US
                    #29
                    Thank you so much for the info.
                    • Ben Sun
                      • Feb 2025
                      • 6
                      Thank you for generating another BIOS. I flashed the BIOS with it and just like the previous one, the computer doesn't POST with that bin.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12423
                        #31
                        Flash again with the original file (lock file) to see if it can be posted ? If it can't be posted, you have accidentally damaged the hardware
                        • Ben Sun
                          • Feb 2025
                          • 6
                          Thank you so much for continuing to assist me.
                          Tl;dr: The very first bin file you sent worked!
                          I flashed back to the original saved bin and it didn't work until I realized the write wasn't working. I erased the IC and was able to flash to original bin onto it and it worked. After doing that I erased the IC again and put the very first bin you sent in response and it worked like a charm. Apologies for not investigating this more before asking for help.
                          • Andromedus_81
                            • Aug 2023
                            • 65
                            • United Kingdom
                            #33
                            Can anyone unlock the password from the bios
                            S/N 8CC05125Q9
                            I am using RC unlocker but the power only comes on for a few seconds and the pc does not respond. Can anyone point out where I can find the right program to delete my forum password?
                            Thank You
                              SMDFlea commented
                              Editing a comment
                              Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
                            • 22170
                            Forum password ?
                            • Andromedus_81
                              • Aug 2023
                              • 65
                              • United Kingdom
                              #35
                              I'm sorry, it's not the password forum, but has anyone tried RC Unlocker with positive results?
                              • danito
                                • Jun 2016
                                • 1218
                                • Romania
                                #36
                                S/N 8CC05125Q9
                                Thank You
                                try
                                • Andromedus_81
                                  • Aug 2023
                                  • 65
                                  • United Kingdom
                                  #37
                                  Hello danito I did as you wrote, reset the settings to factory defaults, but after uploading the original bios the password is still there.
                                  • Andromedus_81
                                    • Aug 2023
                                    • 65
                                    • United Kingdom
                                    #38
                                    I reset the bios to factory settings, but after reinserting the original bios, the password returns. I do this without the cmos battery, but I should insert it before reinserting the original bios?
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12423
                                      #39
                                      Put security in bios by defaut
                                      • Andromedus_81
                                        • Aug 2023
                                        • 65
                                        • United Kingdom
                                        #40
                                        I have reset security then reset the bios to factory settings, saved and confirmed by typing in the numbers that I am resetting the bios but after soldering the original bios there is the password again. what am I doing wrong?
