Fauty BIOS Asus Prime H410M-K R2.0
  • t@ulon123
    • Apr 2014
    • 5
    Hi all, could anybody help me to fix my BIOS. MB turns on but shows no picture.
    thx
    Pavel
  • hoaca388
    Badcaps
    • Jan 2022
    • 12314
    thx
    Pavel
    PRIME H410M-K R2.0
    • Developer AKRAM
      • Feb 2025
      • 12
      • Algeria
      i need BIOS Asus Prime H410M-K R1.00 bin file
      • hoaca388
        Badcaps
        • Jan 2022
        • 12314
        PRIME H410M-K
        • Hamza1995
          • Sep 2022
          • 48
          • Algérie
          REPARER THIS FILE PLZ
          Asus Prime H410M-K R1.01
          • noname2024
            • Aug 2024
            • 291
            • CỎ MỸ XỊN
            Same post #4
            • Hamza1995
              • Sep 2022
              • 48
              • Algérie
              Originally posted by noname2024
              Same post #4
              it does not work and CPU does not heat up
              • noname2024
                • Aug 2024
                • 291
                • CỎ MỸ XỊN
                try
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
