i need bios file HP Pro One 440 G9 12th All-in-one
  • SHARKQ
    • Aug 2023
    • 6
    • INDIA
    Help me
  • volinakis
    • Jan 2021
    • 2873
    • N/A
    Re: i need unlock password file HP Pro One 440 G9 12th All-in-one
    Originally posted by SHARKQ
    Help me
    At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover. Or extract DMI from your bios dump:
    Feature Byte: 3E6J6S6b7B7J7M7Q7S7W7saBapaqataucAcheMfPfQguk8mFmVn7nVngpDpnpqprqjqp.fT (no spaces)
    Serial: 8CN2390B09
    SKU: 73V35PA#AB2
    Build ID: 22WWI4AZ602#SAB2#DAB2
    Board CT: PMQBR0AWBH567B
    Name: HP ProOne 440 G9 All-in-One Desktop PC
    Save and use BCU to exit MPM mode or restart laptop/desktop how many times counter shows.
    REMOVE CMOS BATTERY BEFORE WRITING BIOS!
    • SHARKQ
      • Aug 2023
      • 6
      • INDIA
      Serial: 8CN2390B09
      SKU: 73V35PA#AB2
      Thank you very much , sir
      • akmalbek
        • Feb 2021
        • tashkent
        thank you
        • sher1984
          • Apr 2018
          • Sirdaryo
          hp pro one 440 g9 where is the bios chip, help. This is the first time I've seen this board.
          • amitswami
            Delhi
            • Aug 2021
            • 57
            • rajasthan
            please FIX REPAIR THIS BIOS
            HP ProOne 440 23.8 inch G9 All-in-One Desktop PC RCTO Base Model
            Serial: 1N14230CVR
            P/N : 7F2T8AV
            • hoaca388
              Badcaps
              • Jan 2022
              • 12318
              Serial: 1N14230CVR
              P/N : 7F2T8AV
              HP ProOne 440 23.8 inch G9 All-in-One Desktop PC (7F2T8AV)
              • estwing
                • Apr 2022
                • 6
                • Kenya
                Hello, i need help with the bios for
                6050a3342802-mb-a01
                SN 8CN24101CS
                The current one has no post
                  SMDFlea commented
                  Editing a comment
                  Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.
              • hoaca388
                Badcaps
                • Jan 2022
                • 12318
                6050a3342802-mb-a01
                SN 8CN24101CS
                Try the file in #7 see if it works for you.
                • to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                  by to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                  I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                  This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                  I have opened the laptop and identified the main BIOS chip...
                  10-24-2025, 01:35 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • m1ch43lzm
                  Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                  by m1ch43lzm
                  Hi everyone
                  I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                  Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                  Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                  There's also an extra OTP Secu.R...
                  09-06-2025, 05:47 PM
                • iZakre
                  HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                  by iZakre
                  Hello everybody!
                  To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                  The thing is that I had installed TeamViewer and could log into the computer...
                  02-19-2023, 02:27 PM
                • Forest79
                  by Forest79
                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                  07-23-2023, 07:39 AM
