Help me
i need bios file HP Pro One 440 G9 12th All-in-one
Re: i need unlock password file HP Pro One 440 G9 12th All-in-one
At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover. Or extract DMI from your bios dump:
Feature Byte: 3E6J6S6b7B7J7M7Q7S7W7saBapaqataucAcheMfPfQguk8mFmVn7nVngpDpnpqprqjqp.fT (no spaces)
Serial: 8CN2390B09
SKU: 73V35PA#AB2
Build ID: 22WWI4AZ602#SAB2#DAB2
Board CT: PMQBR0AWBH567B
Name: HP ProOne 440 G9 All-in-One Desktop PC
Save and use BCU to exit MPM mode or restart laptop/desktop how many times counter shows.
REMOVE CMOS BATTERY BEFORE WRITING BIOS!Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Serial: 8CN2390B09
SKU: 73V35PA#AB2
REMOVE CMOS BATTERY BEFORE WRITING BIOS!Comment
please FIX REPAIR THIS BIOS
HP ProOne 440 23.8 inch G9 All-in-One Desktop PC RCTO Base Model
Serial: 1N14230CVR
P/N : 7F2T8AVAttached FilesComment
Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
09-06-2025, 05:47 PM -
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... -
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by maanee11Hello Everyone,
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
- Loading...
