hp z4 g4 bios
  • gts
    • Oct 2014
    • 7
    • india
    Hello , Can any one fix this BIOS , no image ,without ram beep sound coming .I tried many files from this thread but no success.
    • danito
      • Jun 2016
      • 898
      • Romania
      try
      • HAWKAR
        • Sep 2022
        • 5
        • iraq
        Hello guys i read this bios both 32mb 16mb on my hp z4 g4 with xeon w-2195 quadro p4000 workin 100% tested twice
        • mitchw
          HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
          by mitchw
          Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
          After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
          After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
          I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
          04-29-2025, 03:45 PM
        • BlueNitesFire
          I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
          by BlueNitesFire
          So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
          03-08-2025, 03:49 PM
        • Technodoc
          ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
          by Technodoc
          Asus laptop G614JZ-N3012W Rog Strix with i7
          Mainboard G634J-PMV-VGT
          6050A3441302-MB-A01
          2023-02-10
          Power button works okay....power light goes on
          Red "bottom" leds go on
          Charging led works
          Fans do not spin, capslock key does nothing, screen stays black
          I would like to program the bios again, to rule out a corrupted bios.
          However I run into a size error
          The bios chip is a Winbond 25R256JVEN
          Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
          02-24-2025, 04:46 AM
        • ktmmotocross
          Old hp compaq nc6320 weird beeps after low bios battery
          by ktmmotocross
          Hello.
          Have this old hp compaq nc6320 that came with one long and one short beep + backlight on. bios battery have only 0.5V. I remove it, but now it start beep some weird way. I think it is bios /one long + two short beeps+ baklight on/, but when i flash new bios from hp, no beeps and no backlight.
          i attach record of beeps...
          04-27-2025, 12:48 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
