Hello , Can any one fix this BIOS , no image ,without ram beep sound coming .I tried many files from this thread but no success.
hp z4 g4 bios
Attached FilesComment
Hello guys i read this bios both 32mb 16mb on my hp z4 g4 with xeon w-2195 quadro p4000 workin 100% tested twiceComment
I'm currently working on an HP Z4 G4 Workstation and I’m in need of the 16MB BIOS file for this system. The motherboard is labeled:
👉 AS# L09990-001
Unfortunately, the system isn’t booting properly, and I suspect a corrupt BIOS. I’m planning to flash it manually using a CH341A programmer, so I’m specifically looking for the full 16MB SPI dump for the chip MX25L12873F.
If anyone has a working Z4 G4 and could share a dump (or knows where to find an official or clean version), I’d be super grateful!
Thanks in advance 🙏
– CCF
👉 AS# L09990-001
Thanks in advance 🙏
– CCFComment
Every donation made will go towards server fees and maintenance costs.Comment
Type the PC serial number, full name and model, motherboard model, etc.
post the contents of the bios chip even if it is corrupted..
read the forum rules..https://www.badcaps.net/forum/troubl...before-postingComment
HI-- BIOS LEED RED 3 FROM RAM
PLESE HELP ME
serial number.MXL9143CNR
PRODUCT NO. 3WE02UT#ABA
Z4G4/CORE 177800XAttached FilesComment
Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
by mitchwJust had a customer bring in a HP 14s-fq1010nm to do some maintenance.
After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...-
Channel: BIOS Requests ONLY!
So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.2 Photos
by TechnodocAsus laptop G614JZ-N3012W Rog Strix with i7
Mainboard G634J-PMV-VGT
6050A3441302-MB-A01
2023-02-10
Power button works okay....power light goes on
Red "bottom" leds go on
Charging led works
Fans do not spin, capslock key does nothing, screen stays black
I would like to program the bios again, to rule out a corrupted bios.
However I run into a size error
The bios chip is a Winbond 25R256JVEN
Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...-
by ktmmotocrossHello.
Have this old hp compaq nc6320 that came with one long and one short beep + backlight on. bios battery have only 0.5V. I remove it, but now it start beep some weird way. I think it is bios /one long + two short beeps+ baklight on/, but when i flash new bios from hp, no beeps and no backlight.
i attach record of beeps...04-27-2025, 12:48 AM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
