I need unlock BIOS AMI Dfi-Hd100-H81
  • Metaspace
    • May 2023
    • uk
    Hi, I would like to unlock this Dfi-Hd100-H81 motherboard. It is a LGA 1150 mini itx motherboard, there is not much info to be found on the web about this board. The problem is that the bios has no CPU voltage settings, and I would really like to under volt it to save on power. Are there any BIOS mod or a way to unlock the voltage settings, maybe a hidden menu? I will be using it as a pfSense firewall, so the lower, the better.
    If you see any other settings that could be useful add them too if possible, I hope it is. Thanks!
    Bios page link
    http://www.dfi-itox.com/pages/support/mbd/showhd100.htm ( bios name- HD100_071614.zip (3544KB)
  • Metaspace
    • May 2023
    • uk
    Re: I need unlock BIOS AMI Dfi-Hd100-H81
    Sorry there is no bios.zip link to download, not sure how to add it.
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • YG007
      Asus BIOS How To Reset To Default Settings?
      by YG007
      Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
      I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
      06-05-2023, 08:22 PM
      by Vesko356
      08-11-2023, 03:27 AM
