Dell Wyse 5070 BIOS update not possible
  • Stunt
    • Oct 2019
    • 203
    • South Africa
    Originally posted by noTurner
    Hey, you just need to put the jumper on the board to CMOS CLR and leave PW CLR free. Then remove the jumper from CMOS CLR and boot the thin client. (Without putting the jumper on any of the pins)
    It'll then switch to manufacture mode and delete the supervisor password.
    Thanks man it worked
    • bezci
      • Oct 2024
      I would be truly happy if anyone could help with this. I have a Dell Wyse 5070 Extended thin client and upgraded the bios to 1.32.0, downloaded from Dell's support website.
      After the upgrade, BIOS completely changed, and amber blinking started as in the video. According to the guide, the 3+3 blink is a ‘BIOS Recovery 1, Recovery Image not found, Type A' error message. However, I think there is something wrong with the BIOS.
      What I have tried:
      • I formatted the USB to FAT32, put Wyse_5070_1.0.4.exe, Wyse_5070_1.10.2.exe, Wyse_5070_1.32.0.exe on the root, one-by-one, and tried to boot several times with and without nvme. It didn't work.
      • I wanted to flash the BIOS again. However, it freezes on “preparing one-time boot menu…” So I cannot access the BIOS flash tool.
      • I bought a USB keyboard and tried to enter BIOS recovery by pressing Ctrl+ESC. It did not work, and I ended up in EFI shell.
      • There is no “Boot mode” option in the BIOS to switch to legacy mode.
      • I have formatted a USB drive with MS-DOS and plugged it into USB 2.0 ports, so I can run the BIOS flash. It never boots on that USB. (Probably, the client is stuck in UEFI)
      • I bought another Dell Wyse 5070 (not extended) and installed Windows 10 LTSC 2019 on nvme, with all drivers installed. It freezes during booting with the Windows logo.
      • The client freezes when it starts to boot any kind of UEFI OS.
      • It even freezes when I ctrl+alt+del on EFI shell or BIOS screen.
      • I have bought another power adapter, thinking it might be a power issue. Nope, it did not resolve the issue.
      • The boot sequence menu never lists USBs.
      I have been dealing with this for more than a week with searching. As last resort, I am posting. I truly appreciate any help.
      Blink: https://drive.google.com/file/d/1-1o...ew?usp=sharing
      BIOS Screen: https://drive.google.com/file/d/1-LG...ew?usp=sharing
      One time Boot Menu: https://drive.google.com/file/d/1-1e...ew?usp=sharing
      EFI Shell: https://drive.google.com/file/d/1-Gz...ew?usp=sharing
      • capoplays
        Help with BIOS update on Dell G15 5515 after chip replacement
        by capoplays
        Hey everyone,
        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
        When I check the BIOS using the F12 menu Flash...
        10-24-2025, 06:53 AM
      • mikeybass
        by mikeybass
        04-23-2025, 04:30 PM
      • trix11
        Dell Precision T1650 MT Workstation bricked after BIOS update
        by trix11
        I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
        - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
        - Dell Precision T1650 mid tower Workstation
        - Xeon E3-1225 V2
        - 32Gb PC3-12800E RAM
        - 4Tb SATA HDD
        - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
        I see now that others have experienced like issues e.g.:
        - https://www.dell.com/community/Prec...
        10-24-2022, 10:35 PM
      • lalle-
        Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
        by lalle-
        Hello!
        I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
        [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
        I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
        The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
        I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
        08-11-2024, 02:01 PM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
