no power after bios update went bad Alienware r12
  • aalyatim
    • Mar 2022
    • 18
    • usa
    Unplugged the computer during a bios update. Now it powers on for a second and turn off. Im attaching the bios from GD25R256E@SOIC16 if anyone can take a look at it for me. Thank you!!
  • aldopc
    • Jul 2017
    • 470
    • Chilito
    Re: no power after bios update went bad Alienware r12
    Hello, indicate what your service tag is, read your bios again, it's wrong, select wson8, unless your bios is 16-pin...
    • aalyatim
      • Mar 2022
      • 18
      • usa
      I looked for the service tag and its not there on the case. The chip I read it 16 pin unless its not the right one. I found the service tag in the file I posted:
      7ZH6NF3
      • hardware1
        • Sep 2021
        • 2948
        • N/A
        Here's your New BIOS, try it and let me know the results.
        Service Tag: 7ZH6NF3.
        all donations are welcome,
        • aalyatim
          • Mar 2022
          • 18
          • usa
          Thank you for that!
          unfortunately its still doing the same thing, it comes on for a second and turns off. Im starting to think the client isn't telling me the truth by unplugging the PC during bios update. Do you think thats the case?
          • hardware1
            • Sep 2021
            • 2948
            • N/A
            Thank you for that!
            It could be a Hardware problem, but before that you need to be sure that you flashed the file to the chip correctly and the chip is soldered in a proper way. Also you can replace the BIOS chip and test to see if there is any differences.
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • iZakre
              HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
              by iZakre
              Hello everybody!
              To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
              The thing is that I had installed TeamViewer and could log into the computer...
              02-19-2023, 02:27 PM
            • the Benninger
              Vostro 15-3510 During a BIOS update, he ran out of power
              by the Benninger
              Hello community, I have this notebook with BIOS problem, it ran out of power during an update of the BIOS itself, before that it was perfectly , it does not indicate what it charges, it does not turn on any LED or turn the fan, if anyone knows what the DMI direction is here I leave the backup
              I'll be grateful for any help...
              05-17-2024, 12:28 PM
