Unplugged the computer during a bios update. Now it powers on for a second and turn off. Im attaching the bios from GD25R256E@SOIC16 if anyone can take a look at it for me. Thank you!!
no power after bios update went bad Alienware r12
Re: no power after bios update went bad Alienware r12
Hello, indicate what your service tag is, read your bios again, it's wrong, select wson8, unless your bios is 16-pin... -
I looked for the service tag and its not there on the case. The chip I read it 16 pin unless its not the right one. I found the service tag in the file I posted:
7ZH6NF3Comment
Here's your New BIOS, try it and let me know the results.
Service Tag: 7ZH6NF3.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Thank you for that!
unfortunately its still doing the same thing, it comes on for a second and turns off. Im starting to think the client isn't telling me the truth by unplugging the PC during bios update. Do you think thats the case?Comment
It could be a Hardware problem, but before that you need to be sure that you flashed the file to the chip correctly and the chip is soldered in a proper way. Also you can replace the BIOS chip and test to see if there is any differences.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Assuming...7 Photos -
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... -
Hello community, I have this notebook with BIOS problem, it ran out of power during an update of the BIOS itself, before that it was perfectly , it does not indicate what it charges, it does not turn on any LED or turn the fan, if anyone knows what the DMI direction is here I leave the backup
I'll be grateful for any help...-
Channel: BIOS Requests ONLY!
- Loading...
