Asus h310m-c r2.0 bios bin neaded
  • filippok
    • May 2012
    • 19
    • Greece
    Hi, i need update bios to support i7-9700kf (last 2208 asus bios) the only way without a compatible cpu 8th gen is to update with programmer.
    I need a bios dump of 2208 bios plz
    I attach the original one , readed from bios chip
    Thanks for your help
    • 21037
    Re: Asus h310m-c r2.0 bios bin neaded
    Download the bios from Asus support:
    https://www.asus.com/motherboards-co...E-H310M-C-R2-0
    To remove the extra 2KB (CAPsule header) you can use a hex editor, delete 0 - 7FF hex then save. Or you can use UEFITool .Open the bios, select "Action" -> "Capsule" -> "Extract body" ,save as *.rom or *.bin
    UEFITool https://github.com/LongSoft/UEFITool..._A57_win32.zip
    HxD Hex Editor https://mh-nexus.de/en/hxd/
    • filippok
      • May 2012
      • 19
      • Greece
      Thank you, i will try...
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • lrouw84
        Asus vivobook s510ua bios changed to x510un
        by lrouw84
        Hi there,
        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
        01-28-2023, 01:31 PM
