bios for hp all in one dan14tmb6f0
  • peste
    • Dec 2016
    • 12768
    • ROMANIA
    Originally posted by d3try
    Help me!!
    Not booting issue
    HP All-in-One 24-df1010d Bundle PC (397J6PA) Serial: 8CC20125ZR
    Product: 397J6PA
    post motherboard model,post the contents of the bios chip even if it is corrupted..
    • d3try
      • Jul 2020
      • indonesia
      Help me!!
      Not Booting issue
      DAN14TMB6F0 REV F Model : N14T (ROW)
      i5-1135G7
      • peste
        • Dec 2016
        • 12768
        • ROMANIA
        Help me!!
        Not Booting issue
        i5-1135G7
        the bios is corrupt...make another copy and post again..
        • carloseddie83
          • Nov 2019
          • 11
          • México
          Hi, can someone help me? i have an hp aio 22-df1004la, also says 22-df1000i. the board is dan14tmb6f0 rev. F
          it was woring, and i only need to change for another sata ssd.
          i format and reinstall windows, and i was feeling that de "new" ssd was bad. so, chaneged for another new ssd, and clear the TPM... and after clear the TPM... i´m having an acpi bios error and blue screen
          when booting the windows usb.
          i changed the ram, update the bios with hp recovery bios usb. and the same error.
          can some one help? should i program the bios? thank you very much
          • hoaca388
            Badcaps
            • Jan 2022
            • 11717
            You MUST:
            • Read BIOS guides, methods, resources and tools
            • Try the method at BIOS guides, methods, resources and tools before requesting help
            • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
            • Use search function in case someone already answered your request
            • Post under a related thread if it exists
            • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
            • Name your thread with make, full model numbers and request
            • Provide a BIOS/EC dump if possible
            • Attach files directly to your post instead of linking to external websites
            • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
            • carloseddie83
              • Nov 2019
              • 11
              • México
              #26
              please help. hp aio 22-df1004la, also says 22-df1000i. the board is dan14tmb6f0 rev. F
              i cleared the TPM... and after clear the TPM... i´m having an acpi bios error and blue screen when booting windows usb
              nombre del producto: HP All-in-One 22-df1xxx
              familia del sistema: HP OPP
              numero del producto: 140S6AA#ABM
              id placa del sistema: 87F3
              bios: AMI
              version bios: F.48
              numero de serie: 8CC1270P1D
              numero CT placa del sistema: PJSUH0A8JFD2C2
              • hoaca388
                Badcaps
                • Jan 2022
                • 11717
                #27
                bios: AMI
                version bios: F.48
                HP All-in-One 22-df1004la Bundle PC (140S6AA)
                SSID 87F3
                • carloseddie83
                  • Nov 2019
                  • 11
                  • México
                  #28
                  SSID 87F3
                  Thank you, but it keeps saying ACPI BIOS ERROR when trying to boot with windows usb installer.
                  • carloseddie83
                    • Nov 2019
                    • 11
                    • México
                    #29
                    SSID 87F3
                    Please, i need help.
                    • m1ch43lzm
                      • Mar 2019
                      • 410
                      • Peru
                      #30
                      Try the workaround from post 6 https://www.badcaps.net/forum/troubl...os#post3673246
                      Yes, it's the same error on an HP laptop
                      Load setup defaults, and disable the TPM in the BIOS, it should get you past the error
                      • carloseddie83
                        • Nov 2019
                        • 11
                        • México
                        #31
                        Thanks, i already look at that post.
                        I load the setup, disable TPM, also disabled and hide tpm. etc.
                        and the same error, acpi bios error.
                        Please help, i´m trying with windwos 10 (2015 ) and now with win 8.1 just in case.
                        thanks
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • TylerHyde21
                          Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                          by TylerHyde21
                          Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                          I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                          I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                          This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                          06-29-2024, 10:38 AM
                        • Loli Popu
                          DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                          by Loli Popu
                          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                          12-13-2024, 08:29 AM
                        • Ugur87
                          Need Bios or Help for Corrupted Bios.bin XPlus Series 81
                          by Ugur87
                          Hello
                          ive got a brand new Xplus Series 81 mini Notebook, but its not turning on, my friend take it and make something with it, everthing looks fine , charging , power input perfect , fans spinning but no image, now i read the bios chip with ch341a programmer, i think its corrupted, is there any way to fix a corrupted bios bin ? please help...
                          07-14-2025, 06:41 PM
                        • Vesko356
                          by Vesko356
                          08-11-2023, 03:27 AM
