NVR mainboard USB not work, short?
  • stavi
    • Jan 2022
    • 28
    • HUN
    I would like to ask for help to repair an NVR motherboard.
    The NVR itself is working fine, but the USB devices are not. No mouse, keyboard, flashdrive, etc. When plugged in, the mouse does not light up either.
    I have checked the usb pin, I get a very strange voltage:
    I didn't feel much warming (with my hand).
    Where do I start troubleshooting? Any ideas?
    Unfortunately I am a beginner in troubleshooting, but I can solder
    Many Thanks
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    Re: NVR mainboard USB not work, short?
    your measuring is bad. try again
    • stavi
      • Jan 2022
      • 28
      • HUN
      ohhh, you are right
      I was dumb negative was taken from the LAN connector (shielding).
      I remeasured. Now the voltages are better, but still suspect.
      • bbanana
        Father Land
        • Oct 2021
        • 164
        • Vietnam
        Try to remove or replace U6, hope you be lucky
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3622
          • slovakia
          Originally posted by stavi
          ohhh, you are right
          that measurings of upper connector is ok lower have weird voltage on one datapin /4.1V/
          • stavi
            • Jan 2022
            • 28
            • HUN
            You may be right.
            What is U6 (LC5)?
            Can this be measured? I tried, but I got some very confusing values. When how much, several times.
            • harp
              • Jun 2022
              • 634
              • Planet Earth
              Put the mouse into usb port and than do voltage measurement. Is with mouse plugged in still 4.77v on usb connector?
              • stavi
                • Jan 2022
                • 28
                • HUN
                I plugged in a mouse and a USB phone charger to 2x usb. The mouse did not light up, the phone did not charge.
                The U6 voltage did not change.
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  LC5 data sheet ..
                  • harp
                    • Jun 2022
                    • 634
                    • Planet Earth
                    And what is voltage on usb port power pin when mouse is connected? If you have correct voltage present the mouse should light up. Also, usb charger do not use data pin, so only left is 5v to work... if is not work, then no 5v on port, so trace back where is stuck.
                    I dont know what is connection of usb and LC5... there are two of them on each side of pcb. Most likely they do not blown together. For now, dont distract with these.
                    • stavi
                      • Jan 2022
                      • 28
                      • HUN
                      I don't understand
                      I seem to have the VCC 4,8V. But the mouse does not light up, nor does the phone charge.
                      I thought the problem was simpler...
                      • harp
                        • Jun 2022
                        • 634
                        • Planet Earth
                        So, for simplicity use only mouse at time, he is low load device and has led indicator.
                        If you have some simple cheap mouse it will ok, it is much more simply to open than gaming mouse construction.
                        Open the mouse, and do measurement on ending point of cable, where entered into pcb, what voltage you have in mouse?
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3622
                          • slovakia
                          without data pins comunication, mouse not lit even when u have 5V on VCC pin
                          • jiroy
                            • Jun 2016
                            • 2416
                            • Lebanon
                            without data pins comunication, mouse not lit even when u have 5v on vcc pin
                            100%
                            • harp
                              • Jun 2022
                              • 634
                              • Planet Earth
                              Good to known, thank you!
                              So I suggest if is led light needed and expected, that do prior simple test of mouse.
                              Maybe you have just one who need data line to light up...
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3622
                                • slovakia
                                chargers have datapins shorted between them, thats why mouse lid. but USB port cannot have it shorted.
                                it was very long time ago when i checking it. i think without shorted pins phones take only 0.5A and with shorted pins it can take up to 2A. it was with micro usb. dont checking it with USB-C charger
                                • harp
                                  • Jun 2022
                                  • 634
                                  • Planet Earth
                                  Your theory intrigate me, so I test it.
                                  The data pin floating, not touching neither ground or vcc...
                                  But this is apsolutely irrelevant for test mention before, waiting measurement on wire ends.
                                  • 2Stupid4U
                                    Acer Nitro 5 An517-51 mainboard short circuit - Boomer needs help
                                    by 2Stupid4U
                                    Laptop data:
                                    NTB Acer An517-51 FHD
                                    i7-9750H
                                    16GB replaced with RAM Crucial Ballistix SODIMM DDR4-3200 32GB K2 SW
                                    1TB SSD
                                    RTX2060
                                    Bon soir dear online techies, enthusiasts, modest helpers and whomever I might have forgotten!
                                    Search gave me no hits so this is my first post.
                                    My Acer 5 Nitro mainboard had a short circuit when I tried to plugin a USB device. Some smoke rose from the port and it became super hot a that point of entry/exit. Warranty was of about a month.
                                    Since I am on a low budget I cannot afford to buy...
                                    08-29-2023, 01:03 AM
                                  • DynaxSC
                                    Extreme High Current & Low Voltage Short Killer ??
                                    by DynaxSC
                                    Hi Folks
                                    I'm looking for a extreme high current short killer solution for a reasonable cost.
                                    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                    After taking off the socket, the shorts dissappear again.
                                    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                    10-15-2024, 10:13 AM
                                  • Stigsolbjerg
                                    Gardena lawnmowerrobot mainboard, short out battery
                                    by Stigsolbjerg
                                    hi again
                                    this time its a mainboard from a mowerrobot, when i connect battery it shorts it, so the bms shuts down battery.
                                    when take the mm in beepmode and measure from the positive to the negative battery terminal on the board it beeps shortly like 0,25 sec, and when i reverse the probes it beeps again shortly 0,25 sec.
                                    when i mesure on the cap thats missing in pic nr 2, the bottom solderpath goes to the negative, the upper one is 1,2 ohm to negative is this a short?
                                    hope Capleaker is still around
                                    05-27-2024, 02:33 PM
                                  • Stephen
                                    MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                    by Stephen
                                    I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                    02-06-2025, 12:03 PM
                                  • ktmmotocross
                                    MXM GPU 970M not work after GPU phase short
                                    by ktmmotocross
                                    have this MXM GPU 970M that not work after GPU phase short. i removed mosfet to remove short and let it work on two of three phases. card is detected and windows want to instal drivers, but when chceck in GPU-z or HWinfo it shows weird readings.
                                    What else can be bad when have woltages on all coils.
                                    any hint what to check?...
                                    12-19-2021, 04:46 AM
