What if any, is an acceptable resistance here?
  • survivalbloke
    • Aug 2021
    • 316
    On this motherboard(and another like it) I'm getting beeps on diode mode at these coils. I posted the resistance readings to ground. At the risk of sounding dumb, shouldn't all coils be OL on my multimeter when measuring resistance to ground?
    https://imgur.com/A0oCmAz
  • Traceless
    • Jul 2022
    • 12
    Re: What if any, is an acceptable resistance here?
    Undamaged coils will show as a short on a regular multimeter, not open circuit. The resistances you measured there are very likely not the resistances of the coils but resistances of components located between the coils and ground.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3697
      • slovakia
      • hard-enduro
      resistance on coils is ok. it can go down to 1-2ohm on CPU or GPU main power phase
      • survivalbloke
        • Aug 2021
        • 316
        Much appreciated! I'm trying to hone my board skills more and this helps.
        • survivalbloke
          • Aug 2021
          • 316
          Perfect, and thank you. I've got a lot to learn! I got the wrong idea from what I now know as a bad youtube video. I was looking for a fast way to find shorts on a board. Well, not necessarily to pinpoint the short quickly because I would do that with voltage injection and a thermal camera. More like just seeing which power rail the short was on. I was clearly on the wrong track lol.
          • loopster
            645 G9 with Ryzen 5 PRO 5675U | Resistance to ground of CPU?
            by loopster
            Hello everyone, I have a 645 G9 here with a Ryzen 5 PRO 5675U.
            This board has a blown inductor component above the driver chip to the CPU coil, and I am wondering whether the CPU is shorted/dead.
            Could anyone please measure the resistance to ground on the leftmost coil/inductor to the CPU?
            My resistance value is 2.2 Ohms, which doesn't look good to me.
            Thanks to everyone willing to give a value.​
            06-05-2025, 02:33 PM
          • to5it0
            Title: HP EliteBook 840 G3 – Auto Power On Loop, Caps Lock LED Stays On – Need Power Rail Values Near CPU
            by to5it0
            Laptop: HP EliteBook 840 G3
            I’m troubleshooting a motherboard from an HP EliteBook 840 G3 and I’m facing a strange power issue. Problem Description
            • When I plug in the charger, the laptop automatically powers on (without pressing the power button).
            • The Caps Lock LED stays ON continuously.
            • The Power LED, Wi-Fi LED, and Mute LED also turn on.
            • After a few seconds, the laptop turns off, then automatically powers on again, creating a continuous power loop.
            Measurements
            I checked resistance to ground on the three inductors (coils) near...
            03-08-2026, 03:32 PM
          • hcinne
            Dell G15 ryzen edition black screen 2 amber 1 white
            by hcinne
            I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
            07-23-2024, 07:56 AM
          • Mita99
            Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
            by Mita99
            Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
            Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
            Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
            04-27-2025, 07:20 PM
          • Balu56
            PS5 (EDM-010) beeps once, won't start - Missing 1V Core & 1.35V GDDR6 Voltage
            by Balu56
            I'm facing an issue with a PlayStation 5 (Model EDM-010) that I'm currently stuck on, and I was hoping to get your advice.
            Problem Description & Symptoms
            • When I press the power button, the console beeps once briefly.
            • After that, nothing else happens (no blue light, no fan activity).
            Troubleshooting & Measurements So Far
            I have already taken the following diagnostic steps:
            1. Power Supply: I've removed and tested the PSU. It provides a stable 12V.
            2. Visual Inspection: I inspected the motherboard under a microscope
            10-16-2025, 08:03 AM
