P4SD Rev 0W
  • Oerg866
    • Nov 2009
    • 61
    P4SD Rev 0W
    Hi there.
    My friend just got a load of P4SD boards + P4 2.8GHZ from the dumpster. I tested some of them and they were working fine (even fixed some bad caps)... The one I take home is just dead.
    I plug in the power to the PSU and it starts up, and it doesn't post and just sits there. What do I do?
    Cheers,
    Oerg
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: P4SD Rev 0W
    resolder/reflow the CPU Socket (if you have the tools for it)
    otherwise -> no chance
    • Oerg866
      • Nov 2009
      • 61
      Re: P4SD Rev 0W
      OK, I cannot do it professionally but I will try using the method I fixed a few GFX-cards with (just an oven @ 185C 15 minutes...) Who knows, maybe that helps
      • MXM
        • 430
        • Unknown
        Re: P4SD Rev 0W
        check out some of the threads i have posted on P4SD dude... you might find something.
        and yeah who knows maybe the oven works, let us know.
        peace.
        We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
        • Oerg866
          • Nov 2009
          • 61
          Re: P4SD Rev 0W
          Hey thanks for the answers so far but: it doesn't work... Just green light & fan spin, thats all.
          Btw: Where on the front panel header is speaker connector for bios beeps?
          Cheers,
          Oerg
          edit: The heatsink gets REALLY hot too :/
          • Scenic
            o.O
            • Sep 2007
            • 2642
            Re: P4SD Rev 0W
            there's a 2pin header labeled P6 below the southbridge (at the screw hole)
            • howardc64
              Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
              by howardc64
              TV was fixed just after removing Samsung's rear snap cover.
              This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
              Maybe PSU->backlight connector didn't have a good contact?...
              07-23-2025, 12:34 AM
              Asus P4SD-LE-C Motherboard Schematic
              ASUS P4SD-LA (HP OEM) is a motherboard based on the Intel 865G...
              10-21-2024, 05:51 AM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • howardc64
              LG 55UN7000PUA fixed with just dis/reassembly
              by howardc64
              TV runs, backlight on, have sound and no image (dark grey/blue/black LCD)
              Disconnected right (looking from rear of TV) tcon-buffer board cable, LCD left half displays.
              No shorts on right buffer board.
              Started masking tcon-buffer board signals... (connection #1 in main board pic) about 20+ pins from top of connector... LCD fully displays with some anomalies.
              Gradually reduced # of masking signals... eventually down to 1. Removed that... LCD works perfectly.
              No obvious damage on right buffer board 3x COF to the panel like another 43" LG fixed ( link ) with...
              09-19-2024, 11:16 PM
            • CyTECH ELECTRONICS
              Hp Envy 15 with Amd a10 5700m cpu overheats in 1-2 mins
              by CyTECH ELECTRONICS
              I am having trouble with an old HP envy 15 touch with amd a10 5700m cpu.It was with 3 repair shops already they could not fix the not turning on issue.I fixed their mess and fixed the original problem which was?.... of course a shorted cap on the cpu power rail. So now it's all working but the cpu overheats in about 1-2 minutes.
              Repasted properly, the heatsink sits fine on it,the heat is going through the heat pipe and the voltage is around 1.3v to the CPU.
              Pins and the socket are fine.
              Does anyone have any ideas?
              What else can it be ?
              Can the CPU be dead this way?...
              03-07-2025, 03:32 AM
