ASUS AIO ET2012IGKS GPU issue
  • DrFalken
    • May 2008
    • 122
    today has arrived an ASUS AIO ET2012IGKS M/B ET2012E Rev 2.00G.
    GPU (ATI Radeon HD7470M) is almost dead: black screen (frequently) or screen corruption (sometimes).
    Is there a way to disable the Radeon and enable the Intel GPU (HD 2000) ?
    Thank you !
  • dj_ricoh
    • 2073
    Re: ASUS AIO ET2012IGKS GPU issue
    do you have any schematics or boardview of this board?
    you need to find and see what phase goes to the gpu core and try to lift it up. i don`t know if it work but you need to search the forum because i know there are people who manage to convert it.
    • DrFalken
      • May 2008
      • 122
      Hi dj_ricoh,
      I've found the boardview (attached)
      I'm looking for the schematic...
      Thank you !
      • DrFalken
        • May 2008
        • 122
        Removing PQ8947 could do the trick without removing the bad GPU ?
        • delosit
          • May 2021
          • 13
          • italy
          Hello , I have an aio asus et2012e , with broken video card , I bought in china another that works but I do not work the black light on the screen . The fuse on the board was broken I replaced it but it doesn't work the same. With an external monitor everything ok. With the original card the black light works , I do not understand what to check. Has anyone had the same problem? Thank you.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3593
            • slovakia
            fuse dont blow itself
            • fanaticgames
              • May 2017
              • 138
              • italy
              were you able to fix it?
              • delosit
                • May 2021
                • 13
                • italy
                Unfortunately not
                • Glnippon
                  Asus ET2012E v2.00 with a display issue
                  by Glnippon
                  Good mornin everyone!
                  I have a computer all in one Asus ET2012E v2.00 with a display issue. When I put it ON, power LED goes ON, cooling ventilator runs but not nothing on the screen. I had connected to external sceen by HDMI but nothing again.
                  I'm look for motherboard shematics . Any technical information will be helpful
                  Thanks you again!
                  02-01-2025, 03:55 AM
                  AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                  The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                  10-01-2024, 12:46 PM
                • MakNCheese
                  ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                  by MakNCheese
                  I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                  Symptoms:
                  • Severe lag across the system, including BIOS navigation.
                  • Slow boot times and unresponsive performance in Windows.
                  • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                  • No error messages or BSODs, just extreme sluggishness.
                  What I've Tried:
                  • Replaced
                  06-04-2025, 12:48 AM
                • lukkihapsi
                  Asus Vivobook X515JA Weird Boot Issue
                  by lukkihapsi
                  Asus Vivobook X515JA Laptop
                  Issue :
                  Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                  Tried :
                  Cleaned inside for dust, applied fresh thermal paste. No Change!
                  Removed keyboard, Trackpad, fingerprint sensor. No Change!
                  Removed Internal SSD. No Change!
                  Updated BIOS to latest version. No Change!
                  Removed battery and pressing power button for 1 minute. No Change!
                  Weird Part :
                  Upon turning laptop ON, screen lights up - stays black,
                  I...
                  07-07-2025, 12:07 PM
                  AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                  The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                  10-01-2024, 01:07 PM
